Posted: Tue Jul 01, 2008 10:24 pm Post subject: carb help...running rich again |
So my engine has been running rough lately and seems to be getting worse each day. It smells really rich...again
I'm thinking power-valve since i've heard that Holley carbs are notorious for blowing the power valves after a backfire, and i had a backfire last weekend.
Posted: Wed Jul 02, 2008 7:31 am Post subject: |
I've seen a power valve blowout trick to prevent that. I'll have to see where it is. You basically just plug a hole and you're done.
What holley do you have? I have a 650 DP at home waiting for a project to get started... _________________ E30
Posted: Wed Jul 02, 2008 7:42 am Post subject: |
cool, i think its a performance 600 cfm
~JAKE |
Posted: Wed Jul 02, 2008 4:32 pm Post subject: |
| Those don't always work though either. They do help. May I suggest you get an actual Holley brand power valve too.. the napa ones i've tried seem to blow way easy. |
Posted: Wed Jul 02, 2008 10:13 pm Post subject: |
well i got a new holley PV installed today. It seems to be running better so i think that means i've fixed it. I'll be taking a trip to visit my girlfriend this weekend so that will be the true test.
I also managed to break the throttle return spring in the process. easy fix though.
PS I also found out the the holley brand power valve has a lifetime warranty on it, so if i blow it again i shouldn't have to buy a new one.  |
