Injector size?
305 302eater
PostPosted: Tue Jun 10, 2008 4:55 pm    Post subject: Injector size? Reply with quote
Was wondering what size injector everyone thinks is good for running on a stock l98 tpi. On summit I see either 21 lbs or 24 lbs. Will I hurt myself if I run the 24's? They are the same price. Also Were would I find myself a L98 memcal? Thanks for any help guys.
Tim
Thirdgenless
PostPosted: Tue Jun 10, 2008 5:01 pm    Post subject: Reply with quote
running a stock chip, i would run stock sized injectors. If you can tune it, then go with larger.
Isn't stock like 22lbs ??? (not a TPI guy)
305 302eater
PostPosted: Tue Jun 10, 2008 5:11 pm    Post subject: Reply with quote
I'm just giving numbers I found off of summit. My crate should be ready soon so I need to get these things. Also do you think it would benifit me to get a new harmonic balancer or should the stocker do? I cant tune or at least have never been shown how with tpi. Carbs Yes fuel injection not so much. Thanks for the response John.
Thirdgenless
PostPosted: Tue Jun 10, 2008 6:25 pm    Post subject: Reply with quote
What is the motor going in, if it is anything other than stock, you need to get started learning to tune it. The motor and HP, will also help pick the injector sizes.
PostPosted: Tue Jun 10, 2008 6:38 pm    Post subject: Reply with quote
Stock L98 is 22lbs/hr @ 41ish PSI.
Ford injectors are rated at a lower PSI. 39PSI. So if you got Ford 24lb/hr injectors they're more like 25.5lb/hr.
Go with the 21's and get an AFPR.
mrpopo573
PostPosted: Tue Jun 10, 2008 7:35 pm    Post subject: Reply with quote
Lucky bugger is getting a nice crate.
He should be grateful.
To me! Muahaha.
This crate should be nice Timmy, the guy did the motor in our white 442 and you know how that thing runs.
AFPR FTW!
305302eater wrote:
2000 Maxima SE 5 Speed VQ30
mrpopo573
PostPosted: Tue Jun 10, 2008 7:36 pm    Post subject: Reply with quote
Its going in his TPI Iroc. The LB9 is coming out and the L98 Going in with his TPI on top of it.
PostPosted: Tue Jun 10, 2008 8:06 pm    Post subject: Reply with quote
This is true, however personally I would go with the larger ones, and burn a new chip at the same time. You're going to have to start burning chips sooner or later.
PostPosted: Wed Jun 11, 2008 6:43 am    Post subject: Reply with quote
Well... he is going to need a 350 chip reguardless.
PostPosted: Wed Jun 11, 2008 8:03 am    Post subject: Reply with quote
I finally found some ford 24lb injectors for mine. Cant wait to get them installed.
For now just to get it running, Id leave the stock ones in it. Then later as you play, add the 24's
305 302eater
PostPosted: Wed Jun 11, 2008 10:11 am    Post subject: Reply with quote
I don't think I can leave the stock 305 injectors in there cause its a 350 needing a little more fuel. And from what I was just told by dylans dad aka Pspec is that these l98's that this company rebuilds they throw a little more juice in them bumping them to 290 hp. If thats true then should the 21's still be good. And Paul where do you think I could get a l98 memcal from?
Thirdgenless
305 302eater
PostPosted: Wed Jun 11, 2008 10:15 am    Post subject: Reply with quote
To me! Muahaha.
AFPR FTW!
OK did you just get done watching a top gear episode, "bugger"? Anyways just talked to Pspec and he said that the builder said they rebuild them to a higher spec hp wise and he was wondering if I was ok with this? Laughing
Thirdgenless
PostPosted: Wed Jun 11, 2008 11:04 am    Post subject: Reply with quote
GMparts direct.
What year is your car?
PostPosted: Wed Jun 11, 2008 11:09 am    Post subject: Reply with quote
oh, forgot about the 305 to 350 swap part.
heres the actual formula for a N/A engine.
lb=(hp x .50)/(6.4)
lb=(290 x .50)/6.4)
lb=22.65
so toss in the 21lb and bump up the fp.
305 302eater
PostPosted: Wed Jun 11, 2008 12:04 pm    Post subject: Reply with quote
GMparts direct.
Its a 89 Iroc.
Thirdgenless
PostPosted: Wed Jun 11, 2008 1:23 pm    Post subject: Reply with quote
305 302eater wrote:
GMparts direct.
Its a 89 Iroc.
Two part #'s I found for an 89 '165 prom:
16150502-350, 700r4, 3.27R -- Discontinued
16150499-350, 700r4, 2.77R -- $94.50
HTH
EDIT: Right when I hit submit I saw you sent me that PM. haha
305 302eater
PostPosted: Wed Jun 11, 2008 1:50 pm    Post subject: Reply with quote
305 302eater wrote:
GMparts direct.
Its a 89 Iroc.
HTH
LOL thanks Ian, thats hilarious. So that memcal should work though right? When can I come pick it up?
Thirdgenless
PostPosted: Wed Jun 11, 2008 2:08 pm    Post subject: Reply with quote
Wow they went up. When I got mine a few years ago it was only like $45 from GMPD.
The lower numerical gear memcal should work fine.
I'd still get the adjustable AFPR so you can sort of dial in the "hopped up" motor you have.
PostPosted: Wed Jun 11, 2008 2:33 pm    Post subject: Reply with quote
I just ordered it right now and it's coming from Tennessee so that'll probably be saturday or tuesday (we don't get freight on mondays). I've got your number, I'll ring you when it comes in. Smile
305 302eater
PostPosted: Wed Jun 11, 2008 2:34 pm    Post subject: Reply with quote
OK paul I'll get the AFPR for my weak and lame motor. Laughing
I thought the memcal should work fine just wanted to be sure. Very Happy
Thirdgenless
