KYB GAS-A-JUST??????
WS6FORMULA
PostPosted: Mon Apr 07, 2008 7:19 pm    Post subject: KYB GAS-A-JUST?????? Reply with quote
sooo anyone have those just wondering how they are my car needs new struts and i figuered it out OEM aftermarket are around 150 and badass kinds around 200 so im goin big..
how are those KYB ones
PostPosted: Mon Apr 07, 2008 7:33 pm    Post subject: Reply with quote
I think the KYB is the best bang for the buck. I've been running mine for going on 6 years in the front.
If you're going to road race or something... I'd go with the Koni's.
I doubt your average driver could really tell a difference.
PostPosted: Mon Apr 07, 2008 7:54 pm    Post subject: Reply with quote
I have been running KYB's since I got my GTA. I think that she handles pretty good. I am looking to upgrade to Koni sports at this point but for the money I don't think you can go wrong.
Enjoy!
WS6FORMULA
so like will i feel a difference stiffness wise???
PostPosted: Mon Apr 07, 2008 8:47 pm    Post subject: Reply with quote
i have them on all 4's. they were on the car when i bought it so i dont know how many miles are on them, but there great. i work at an auto parts store and i always recommend KYB's because they aren't much more than cheapies like gabriel's or monroe's. and there 10 times better. Smile
'88 FORMULA
WS6FORMULA
PostPosted: Mon Apr 07, 2008 8:53 pm    Post subject: Reply with quote
ok sweet well im ordering some asap
KYBs are a fair improvement over stockers in good condition.
It's not really a stiffness thing. More of a control thing. Stiffness is in sway bar and spring.
WS6FORMULA
PostPosted: Mon Apr 07, 2008 8:55 pm    Post subject: Reply with quote
ok well since my birthday is coming up what do you all recommend for lowering but also stiff springs
PostPosted: Mon Apr 07, 2008 9:02 pm    Post subject: Reply with quote
How low do you want to go? The Eibach Sportlines are my fave.... execpt I'm poor and cut my springs. Cutting worked fantastic in the front. Still a little squishy in the back... but might be the drag shocks.
PostPosted: Mon Apr 07, 2008 9:04 pm    Post subject: Reply with quote
Agreed. I noticed a big difference in my 89 RS when I installed Brandon's (chevymad) WS6 springs and larger sway bars. It was a bigger difference than the prior install of gas adjustable socks & struts.
PostPosted: Mon Apr 07, 2008 9:06 pm    Post subject: Reply with quote
Huge difference going from monroe's to kyb. I used Hotchkis springs to lower mine. Dropped it quite a bit. I do like them though.
WS6FORMULA
PostPosted: Mon Apr 07, 2008 9:19 pm    Post subject: Reply with quote
well i want like a inch and a half ish but i dont want that ricer honda cut spring effect you know what i mean
PostPosted: Mon Apr 07, 2008 9:29 pm    Post subject: Reply with quote
Know what you mean. My car rides similar to Chevymad's with the Hotchkis and Schultzy with the Sportlines.
To get our cars to do the ricer thing you'd have to cut a huge amount and make it virtually ride on the bumpstops.
WS6FORMULA
PostPosted: Mon Apr 07, 2008 9:46 pm    Post subject: Reply with quote
so are the sport lines or the pro kit stiffer
i think they are the pro kit is
but so if i cut a lil off from those should i be fine
PostPosted: Mon Apr 07, 2008 9:57 pm    Post subject: Reply with quote
Don't cut springs you buy. If you're going to cut, cut springs you have.
The sportline would be a little stiffer. It has the steeper drop.
The eibachs are progressive springs. So the more the spring compresses the spring rate increases more than a regular spring.
WS6FORMULA
PostPosted: Tue Apr 08, 2008 12:02 am    Post subject: Reply with quote
ok so im getting out of this is buy the sport line and dont cut them =]
PostPosted: Tue Apr 08, 2008 6:30 am    Post subject: Reply with quote
Or the Hotchkis :O)
PostPosted: Tue Apr 08, 2008 7:19 am    Post subject: Reply with quote
Exclamation
You know....
Was thinking about this and discussing ride height/handling last night with a friend of mine for my car. He also reccomended the KYB's and dropping the ride height of my car about 2-3".
Weird.
PostPosted: Tue Apr 08, 2008 9:05 am    Post subject: Reply with quote
I have KYB-GR2's on both my cars. Little on the stiff side, but I dont mind.
I dont .. think... you could lower an fbody 3" and still drive it. Mine is around 2 and drag quite a bit.
PostPosted: Tue Apr 08, 2008 10:00 am    Post subject: Reply with quote
i will say if you JUST replace the shocks, you may not notice a difference. i put KYBs on and my car does not really feel any different. i need new springs though, mine are sagged.
