Rear disc brake lines
PostPosted: Wed Feb 27, 2008 8:03 pm    Post subject: Rear disc brake lines Reply with quote
I just finished removing the discs and rotors from my newly acquired rear axle. The passenger side brake line is broken off at the caliper, the driver side appears to be OK. I would like to replace the whole thing, including the feed line to the splitter at the differential. Where can I find these pre-formed?
PostPosted: Wed Feb 27, 2008 8:06 pm    Post subject: Reply with quote
Check out this thread on TGO. Just saw it the other day.
http://www.thirdgen.org/techboard/brake-board/462263-pre-bent-brake-lines.html
PostPosted: Wed Feb 27, 2008 8:12 pm    Post subject: Reply with quote
Thank, I saw that too, but I'm not positive on the fittings I need on the ends. The axle is vintage 1982, so I'm assuming standard fittings instead of metric Confused
PostPosted: Wed Feb 27, 2008 9:15 pm    Post subject: Reply with quote
correct you are sir. metric switch happened in mid 83 i believe.
PostPosted: Wed Feb 27, 2008 11:23 pm    Post subject: Reply with quote
you can also buy plain straight tubing from most parts stores like napa in standard lengths. then you just have to bend it in place. Not very hard, cuz the stuff bends really easy. Just bend it around the neck of your favorite tall boy so it doesn't kink. WAY cheaper this way.
