Red Bird Member
1991 Pontiac Firebird
Posted: Tue Jan 15, 2008 7:43 pm Post subject: poly bushings |
ive got a 36mm front sway bar, and am looking for poly bushings for the mounts, end links. anyone have a brand name/part # that they have had a good experience with? _________________ 1991 Firebird L03 T-5 |
Posted: Tue Jan 15, 2008 7:48 pm Post subject: |
Energy suspension sells them. I can get the part number a little later, it should be an easy search though.
--John |
Posted: Tue Jan 15, 2008 8:05 pm Post subject: |
I tried looking through the ES catalog the other day at work and never found a 36mm sway bar bushing, just the 35. Close enough? _________________
Red Bird Member
Posted: Tue Jan 15, 2008 8:55 pm Post subject: |
Yeah i was on summits website, and the largest they had listed was for a 34mm bar. so the search continues. _________________ 1991 Firebird L03 T-5 |
Posted: Tue Jan 15, 2008 9:06 pm Post subject: |
| I believe you have to sand/ream out the bushings to fit. Mine came with my energy suspension kit and thats what they had me do to fit the 36mm bar. |
Posted: Wed Jan 16, 2008 6:50 am Post subject: |
I think topdownsolutions takes the 34mm and modifies them to fit 36.
youd thunk by now that ES would be on the ball and sell 36's. |
Posted: Wed Jan 16, 2008 9:01 am Post subject: |
Don't know about the 36mm bushings, but I can get endlinks with urethane from the local parts store for $7 a piece. Thats the complete endlink with thick washers, nylon lock nut, and correct length bolt with spacer.
I was half joking when I asked the guy the first time, but he was like, "Yup, got 5 in the back, how many do you want?" _________________ E30
Posted: Wed Jan 16, 2008 9:10 am Post subject: |
| blue89 wrote: | Don't know about the 36mm bushings, but I can get endlinks with urethane from the local parts store for $7 a piece. Thats the complete endlink with thick washers, nylon lock nut, and correct length bolt with spacer.
I was half joking when I asked the guy the first time, but he was like, "Yup, got 5 in the back, how many do you want?" |
5?! but aren't they like B**bies and you want them in pairs? (.)(.)(.)  _________________ 1983 Z-28 5.7 LT1, T56, Headman headers, BW 9 Bolt Posi Disc, WS6 suspension
Posted: Wed Jan 16, 2008 9:28 am Post subject: |
True, I'm just saying the parts store will have pre-assembled endlinks for cheap.
Funny, I just ordered 34mm urethane bushings for the LT1. |
Posted: Wed Jan 16, 2008 10:30 am Post subject: |
They sell the endlinks in pairs I thought?
unless they sell the cheapo rubber ones individual because people dont want to replace "whats not broken".
| 83Z28BlackBetty wrote: | but aren't they like B**bies and you want them in pairs? (.)(.)(.)  |
I'll take 3  |
Red Bird Member
Posted: Wed Jan 16, 2008 8:46 pm Post subject: |
so the only 36 mm mount bushings i could find are rubber, i think im gonna use the rubber mount bushings, and poly end links. _________________ 1991 Firebird L03 T-5 |
Posted: Wed Jan 16, 2008 9:26 pm Post subject: |
One of the first mods that I did to the GTA was poly sway bar bushings and endlinks. Little dollars and noticable change.
I used the 35mm Energy Suspension greasable sway bar bushings 7 or 8 years ago. I didn't sand them down just ran them as is... no problems.
As far as why they don't sell 36mm sway bar bushings... not that common. These are big ass sway bars; not that common.
Good luck, have fun!
Red Bird Member
Posted: Thu Jan 17, 2008 7:14 pm Post subject: got em |
so i ordered some 35mm energey suspension bushings/endlinks for summit. 40 bux for the right size was a bit too steep for my budget, i got the 35mm mounts and endlinks for the same price. _________________ 1991 Firebird L03 T-5 |
