Radiator Cap Poundage?
PostPosted: Wed Jan 09, 2008 9:43 pm    Post subject: Radiator Cap Poundage? Reply with quote
What specifies radiator cap lbs?
The radiator itself, the water pump, the flow, etc?
PostPosted: Wed Jan 09, 2008 10:16 pm    Post subject: Reply with quote
Engine design.. How many psi of pressure does it take to prevent steam pockets.
PostPosted: Thu Jan 10, 2008 12:25 am    Post subject: Reply with quote
you want a 16 LB cap for the 2.8 paul.
PostPosted: Thu Jan 10, 2008 7:14 am    Post subject: Reply with quote
The Corolla rad came with a 7lb cap. Wanted to make sure if I put a 16 lb on I wouldn't be hurting the rad.
