leaking trunk
PostPosted: Wed Jan 09, 2008 4:43 pm    Post subject: leaking trunk Reply with quote
anyone know where the common or w/e places it leaks from?
idk where it is coming from but i know the the motor is pulling it down pretty good
-Donald
PostPosted: Wed Jan 09, 2008 4:47 pm    Post subject: Reply with quote
The seam where the weather stripping comes together, right in the center is a place that mine has leaked from. I gooped it up, and having had a leaking issue since. Since you can get in the hatch of our cars, you can always close the hatch, get lean into the back, and have a buddy hose down the rear, and see if you can find the leak.
--John
PostPosted: Wed Jan 09, 2008 5:21 pm    Post subject: Reply with quote
If you have a spoiler, they can leak through the mounting bolts and appear to be the gasket. Mine did that, actually its doing it again with my new hatch. Just take the plastic off to get access to the spoiler nuts, take the nuts looks then apply rtv under them.
PostPosted: Thu Jan 10, 2008 1:49 am    Post subject: Reply with quote
On mine there is a seam where the hatch meets the flat deck that has caused leaks because the weatherstrip doesn't get a good seal against the uneven surface.
PostPosted: Thu Jan 10, 2008 4:33 am    Post subject: Reply with quote
x2 on mine. It leaked where the glass met the deck.
Sounds stupid, but remove all the trim panels you can back there. Then you crawl in and have someone turn a water hose on the car and see what it does.
