popballz Member
Posted: Wed Jan 09, 2008 4:43 pm Post subject: leaking trunk |
anyone know where the common or w/e places it leaks from?
idk where it is coming from but i know the the motor is pulling it down pretty good _________________ -Donald
Posted: Wed Jan 09, 2008 4:47 pm Post subject: |
The seam where the weather stripping comes together, right in the center is a place that mine has leaked from. I gooped it up, and having had a leaking issue since. Since you can get in the hatch of our cars, you can always close the hatch, get lean into the back, and have a buddy hose down the rear, and see if you can find the leak.
--John |
Posted: Wed Jan 09, 2008 5:21 pm Post subject: |
| If you have a spoiler, they can leak through the mounting bolts and appear to be the gasket. Mine did that, actually its doing it again with my new hatch. Just take the plastic off to get access to the spoiler nuts, take the nuts looks then apply rtv under them. |
Posted: Thu Jan 10, 2008 1:49 am Post subject: |
| On mine there is a seam where the hatch meets the flat deck that has caused leaks because the weatherstrip doesn't get a good seal against the uneven surface. |
Posted: Thu Jan 10, 2008 4:33 am Post subject: |
| aaron_sK wrote: | | On mine there is a seam where the hatch meets the flat deck that has caused leaks because the weatherstrip doesn't get a good seal against the uneven surface. |
x2 on mine. It leaked where the glass met the deck.
Sounds stupid, but remove all the trim panels you can back there. Then you crawl in and have someone turn a water hose on the car and see what it does. |
