proportioning valve
PostPosted: Fri Jan 04, 2008 12:27 pm    Post subject: proportioning valve Reply with quote
whats the process on this?
where should i install?
i need to cut the hardline, slide the male connecter on, and flare it?
advice?
PostPosted: Fri Jan 04, 2008 12:40 pm    Post subject: Reply with quote
I've posted this before I'm sure. Are you bypassing your stock prop valve? The hardest thing will be to get the right male ends. If you get rid of your stock prop, you'll have to tee the front lines together. Look at my pic and ask more questions.
PostPosted: Fri Jan 04, 2008 12:44 pm    Post subject: Reply with quote
Or use this opportunity to install a linelock, which most have dual exit ports. Very Happy
PostPosted: Fri Jan 04, 2008 1:02 pm    Post subject: Reply with quote
First, we need more info.
I know you changed your rear axle, so you are changing this... I'm guessing.
Now, are you installing a factory J65, or an aftermarket?
If your installing a factory J65, just make sure you get a period correct one. I think they changed threads in 89?
If your doing aftermarket, you will need to give info on the valve.
PostPosted: Sun Jan 06, 2008 9:32 am    Post subject: Reply with quote
well after multiple trips to the parts store i finally got it together! although it has like 9 billion adapters... it holds and i can brake Very Happy
PostPosted: Mon Jan 07, 2008 8:29 am    Post subject: Reply with quote
What did you put in? I feel you on the adapters, I have quite a few myself. As long as it doesn't leak its all good. Take a pic and post it!
