Posted: Sat Dec 29, 2007 3:56 pm Post subject: After headers o2 weirdness |
Before I installed my headers, I had a crushed 2.25 y-pipe, manifolds, stock cat. I was getting left n right o2 readings within 1-2% of each other.
So I got my headers installed, custom y-pipe, for now no cat converter(gotta order a 3" one). O2 sensors are in almost same exact location. They are completely different now. One side is adding 30 to 50%fuel. Other side is removing 12-15%
When in open loop(cold) it runs GREAT. But when its in closed loop(warm) it runs like ass now
What would have went wrong that I am getting this wack of o2 readings now?
Posted: Sat Dec 29, 2007 4:17 pm Post subject: |
Exhaust leak? _________________
Posted: Sat Dec 29, 2007 4:28 pm Post subject: |
just crawled under and checked.
No leaks at heads.
Both mounts to y-pipe are not leaking.
So if there leaking, its in the actual headers. |
Posted: Sun Dec 30, 2007 12:15 pm Post subject: |
Figured it out.
Still quite a bit of difference, but atleast both are doing the same thing now. |
Posted: Sun Dec 30, 2007 12:23 pm Post subject: |
What was it?
Posted: Sun Dec 30, 2007 5:20 pm Post subject: |
The wires to the 02 sensors got switched while they were disconnected.
Bank 1 had bank 2 sensor
Bank 2 ahd bank 1 sensor
Posted: Sun Dec 30, 2007 5:22 pm Post subject: |
LOL atleast you found it.
What are you running that runs two O2? |
Posted: Mon Dec 31, 2007 8:25 am Post subject: |
| OBD2/Sequential fire on a TPI intake. |
Posted: Mon Dec 31, 2007 5:43 pm Post subject: |
| Nice |
Posted: Wed Jan 02, 2008 8:51 am Post subject: |
| Aha! Thats good you figured that out! What a wierd problem huh? |
