Posted: Sun Dec 02, 2007 9:59 pm Post subject: Air pump disable? |
Forum update killed my old topic about this, so I'll repost.
How do you disable the air pump in a 6E BIN in TunerPro? Found a few topics with later MAP BINS on TGO, but no good answer for how to do it with 6E. |
Posted: Mon Dec 03, 2007 12:00 am Post subject: |
| You can unplug the thing and not change anything in the chip and be fine. |
Posted: Mon Dec 03, 2007 12:07 am Post subject: |
Okay. That makes it easy. I've read conflicting info on TGO about whether or not the O2 sensor is changed when the air pump is diverting into the manifolds, but I haven't found any indication of it in TunerPro.
Thanks man. |
Posted: Mon Dec 03, 2007 12:13 am Post subject: |
From what I understand the air pump really only comes into play when the engine is cold, injecting air into the cat to help burn the cold emissions. At that point the O2 isn't being read anyways.
Might pull up a wiring diagram. It may be wired by temp switch even. If you're lucky :O) |
Posted: Mon Dec 03, 2007 10:29 am Post subject: |
| There is a correction factor on the O2 reading that jumps it up by 2 AF points when the air pump kicks on. So basically it mods the target AF with the pump on cause it knows it has additional air. You need to go in a disable that by making the correction factor 0. I don't remember where it is but I can look when I get home. |
Posted: Mon Dec 03, 2007 7:59 pm Post subject: |
| Was there a correction factor in all BIN's, or just later ones? The stuff I've seen on TGO mainly refferenced the $8D or whatever. |
fiveoformula Member
Posted: Mon Dec 03, 2007 8:16 pm Post subject: |
sorry to get off topic but i had question about the airpump aswell, how do you delete it from the serpentine system? short belt? delete bracket? _________________
'88 FORMULA |
Posted: Tue Dec 04, 2007 7:31 am Post subject: |
My vee-six has a shorter belt. Its a long run from the alternator to the crank but it stays on. Pretty hard to find the right belt too! I can pull a number from a belt label I keep in the glovebox. Yet another task to accomplish when I get home....
I ran mine without the air pump or chip mod for some time. Just might run a little lean on you. I never noticed anything. _________________ E30
Posted: Tue Dec 04, 2007 11:54 am Post subject: |
| blue89 wrote: | | I ran mine without the air pump or chip mod for some time. Just might run a little lean on you. I never noticed anything. |
ditto on my 86 2.8. still have not modded the chip |
fiveoformula Member
Posted: Tue Dec 04, 2007 4:13 pm Post subject: |
hmmm if you run a little lean wouldnt that be better on emissions? _________________
'88 FORMULA |
Posted: Tue Dec 04, 2007 4:15 pm Post subject: |
| fiveoformula wrote: | | hmmm if you run a little lean wouldnt that be better on emissions? |
It gets tricky in Oregon. As you lean the mixture out, the combustion process outputs a higher pecentage of NOX. Although your HC count will go down, NOX goes up. In WA, their emmisions don't test for NOX, but they do test it here in Oregon.
--John |
fiveoformula Member
Posted: Tue Dec 04, 2007 4:22 pm Post subject: |
| Dewey316 wrote: | | fiveoformula wrote: | | hmmm if you run a little lean wouldnt that be better on emissions? |
--John |
would it be a considerable amount? like very noticable?, the only reason i wanna git rid of mine is because it rattles, and probly doesnt do anything anymore _________________
'88 FORMULA |
Posted: Wed Dec 05, 2007 12:29 am Post subject: |
if it's not doing anything now, removing it would change nothing.
when i removed mine my emissions numbers did not change a bit. i did a deq cheack before and after removing it. on the same day, with the same gas. there was NO difference in any of the numbers.
mine must have been broken. |
Posted: Wed Dec 05, 2007 7:17 am Post subject: |
| Xophertony wrote: | if it's not doing anything now, removing it would change nothing.
It only works COLD. |
Posted: Wed Dec 05, 2007 12:34 pm Post subject: |
oh.. yeah.
so if you go through deq with a cold engine it might change. |
Posted: Wed Dec 05, 2007 4:43 pm Post subject: |
| Twilightoptics wrote: | | Xophertony wrote: | if it's not doing anything now, removing it would change nothing.
I was under the impression it pumps air randomly throughout driving. Or at least air is pumped into the manifolds. That's from post by I think TRAXION on TGO about disabling the 100mv offset that's enabled when air is injected. |
Posted: Wed Dec 05, 2007 4:49 pm Post subject: |
I thought it only injected into the manifolds cold, and that it injected air straight into the catalyst when it was warmed up.
--John |
Posted: Wed Dec 05, 2007 4:52 pm Post subject: |
| Maybe I missread by I thought it was the otherway around. Cat while cold to help make the treehuggers happy and manifold during light and part-throttle cruise. |
