I think my car is the car from hell!!! (kinda long)
PostPosted: Wed Oct 31, 2007 5:15 pm    Post subject: I think my car is the car from hell!!! (kinda long) Reply with quote
What started as a wiring project, intake, timing cover, dizzy swap to take 30 days is now 70 days in and no light at the end of the tunnel.
1. Swap timing cover, get in and see it has a double roller which wont work for my project. Go get new TC, wont fit, go swap again. Get cover on.
2. Go to swap intake, didnt know about the different bolt patterns, One I got does not match my heads. I take the one I have a mod it to fit.
3. Get into the wire harness(modding a gm one to fit my needs). Find out its designed reverse of what I need. Whatever, I'm modding it anyway, just makes it a bit harder. Needed some wire diagrams I didnt have and didnt know I would need. Played hell finding them.
4. Making an EGR mount proved harder then I thought, but it got made.
5. Thought I had found some OTC plug wires (only one year car). They werent long enough, had to get some other OTC's and put a custom end on it.
6. Go to start it starts dies. Starts, dies, starts, dies. Find out the ecm I am using has anti theft, no diagram showed that. (By now its 30 days)
7. Send ecm off to a guy 3 hrs away to get that and a few other things fixed expressing my "needed it yesterday" needs. As of today, he still had not mailed it out.
8. Because of 7, I get pissed a few weeks ago, get another ecm and buy the program to mod the ecm myself. Get it started..
9. While filing with antifreeze I see holy oil leak batman!!!
10. Find out I cracked the plastic Timing cover. Order NEW cover.
11. Go to put new TC on, I rip the oil pan gasket, $hit!!!!
12. Go to borrow hoist to lift motor, dent dads truck.
13. Go to lift motor up 4-6" tonight, still cant get oil pan off. So It appears I have to pull trans off to beable to wiggle the oil pan off.
14. Go to pick up mess, door wont close due to hoist.
15. Have to take car back down off ramps to roll it, car has to be far back as possible, so now I cant get in MY tool box.
16. Go to slide hoist under car, bang, bang, bang. WTF? Car is so low, the hoist hits the cross member, so I have to jack it BACK up NOW.
When will it ever end? This wire harness/ecm swap better be f-ing worth it!!!!
So, question...........
is there ANY way possible to get the oil pan off w/o pulling trans, and w/o pulling the motor all the way out and still leave my wire harness, fuel lines, ps, etc all still hooked up?
(good news, its a 4bolt main with a windage tray. WOOT.)
Sellmanb
PostPosted: Wed Oct 31, 2007 6:54 pm    Post subject: Reply with quote
I did it on my old camaro, with a stock 2 bolt main and stock oil pan. Had to jack up the motor from the balancer, unbolt the motor mounts, and unbolt the trans mount. Then from there it was just a question of "how high" lol. Remember though, you'll have to turn the balancer so you can clear the crank.
PostPosted: Wed Oct 31, 2007 7:57 pm    Post subject: Reply with quote
I replaced my oil pan gasket and rear main(two piece) w/o a picker. Get a felpro one piece pan gasket. Scraping the old off is the hardest part. Jacked the balancer up and the trans up.
It's a PITA, but can be done.
PostPosted: Thu Nov 01, 2007 2:44 am    Post subject: Reply with quote
How high do you have to go? How high will the hoses let me go?
Spining the crank will do me no good. The wind tray is attached below that.
PostPosted: Thu Nov 01, 2007 6:15 am    Post subject: Reply with quote
High enough to scrape the old out and put the new one on. The one piece rubber can go on from the outside. Stretches to slide around the whole pan.
I don't think you can get the pan off without pulling the flywheel... in car. Even then it's iffy.
PostPosted: Thu Nov 01, 2007 7:09 am    Post subject: Reply with quote
Didnt think about stretching it around the pan from the outside. I was thinking trying to wiggle it between the pan and oil pump. Thanks.
I see another attempt at it tonight Twisted Evil
kenf729
PostPosted: Fri Nov 02, 2007 2:06 pm    Post subject: Reply with quote
Just a thought...when you are jacking the motor up be sure to watch the dizzy...
kenf729
PostPosted: Fri Nov 02, 2007 2:07 pm    Post subject: Reply with quote
edit: sorry about that computer issues...
PostPosted: Fri Nov 02, 2007 5:30 pm    Post subject: Reply with quote
Twilight, you are the freakin man!!! Gasket went on over the outside, and all that crap fit up like a bought halloween costume!!!
In 2 hrs the motor came up, pan is on, timing cover, balancer, pully motor back down, ignition on, bolts thru the motor mounts, fixed a antifreeze drain plug.
Calling it a night because I need water pump gaskets, and 4qts of oil.
Ken, thats for the reminder but I was keeping an eye on it. I dont have a stock dizzy so it cleared with zero issues.
Wait tell you see a picture of this y-pipe I gotta put back on because of cash flow. Ewwwww Anyone know where I can get just the ball side of a 2.5" ball n flange exhaust joint? Summit wants 50 Shocked
PostPosted: Sat Nov 03, 2007 1:28 am    Post subject: Reply with quote
I think I might have the ball side. I'll look.
PostPosted: Sat Nov 03, 2007 9:05 am    Post subject: Reply with quote
Rock on!
Just passin the information along to the next!
PostPosted: Sat Nov 03, 2007 11:12 am    Post subject: Reply with quote
looks like I just have two extra flange sides. Sorry.
PostPosted: Sat Nov 03, 2007 3:38 pm    Post subject: Reply with quote
Thats for looking quasi
Car is back together and atleast moves. Doesnt like to idle and is still running pig rich. So looks like I get to do alot of tuning.
If anyone has experience with EFI live and 0411 ecms, let a guy know, for sure need some help.
