LB985IROC Member
1995 Chevrolet Camaro Z/28
Posted: Wed Oct 24, 2007 5:20 pm Post subject: 92 tbi dies intermitantly |
i juts got myself a nice 92 rs 305 tbi car and it dies intermitantly and wont restart for a few m ins and it dies again soon afterthe longer i let it sit and cool the longer it runs for its getting spark while it wont start and you can hear the pump buzzing after you let off bthe ignition when it wont start my replaced the ign coil and the ign module with no results _________________ Cadillac of Bellevue
Retail parts sales
fiveoformula Member
Posted: Wed Oct 24, 2007 7:25 pm Post subject: |
how about when it runs, does it run crappy? _________________
'88 FORMULA |
LB985IROC Member
Posted: Wed Oct 24, 2007 7:44 pm Post subject: |
it seems to run alright and have good power but it idles kinda rough like it has a misfire _________________ Cadillac of Bellevue
Retail parts sales
Posted: Wed Oct 24, 2007 7:49 pm Post subject: |
| Have you checked the fuel pressure at the rail? |
Posted: Wed Oct 24, 2007 7:56 pm Post subject: |
Its TBI, there is no rail, and it is kind of a pain to check fuel pressure.
Have you done the normal tune up stuff? I would check the fuel filter, and give it new plugs/wires/cap/rotor, and also check the timing.
--John |
Posted: Wed Oct 24, 2007 8:15 pm Post subject: |
| Dewey316 wrote: | | Its TBI, there is no rail, and it is kind of a pain to check fuel pressure. |
For some reason I read TPI. nm that... |
LB985IROC Member
Posted: Wed Oct 24, 2007 8:19 pm Post subject: |
it has new cap and rotor old plugs and wires and not sure about the filter _________________ Cadillac of Bellevue
Retail parts sales
fiveoformula Member
Posted: Wed Oct 24, 2007 8:34 pm Post subject: |
i was thinkin fuel filter. id start with that if you dont know the last time its been replaced, its like a 8 dollar part... if thats not it, plugs n wires _________________
'88 FORMULA |
LB985IROC Member
Posted: Thu Oct 25, 2007 5:00 pm Post subject: |
okay new developement the plugs are missmatched between autrolites and bosch platinums....and the resistance on the wires is so out of wack that its causing the coil to over heat and thats what we are sure is causing the problme and i bought a fuel filter too for good measure _________________ Cadillac of Bellevue
Retail parts sales
fiveoformula Member
Posted: Fri Oct 26, 2007 9:27 pm Post subject: |
| LB985IROC wrote: | | okay new developement the plugs are missmatched between autrolites and bosch platinums....and the resistance on the wires is so out of wack that its causing the coil to over heat and thats what we are sure is causing the problme and i bought a fuel filter too for good measure |
dang... wonder what brilliant mind decided to do that... what plugs did you go with? _________________
'88 FORMULA |
Posted: Sat Oct 27, 2007 1:53 am Post subject: |
and here I was just about to ask if you were running Bosch plugs.  _________________ Richmond 3.73 posi| 36/24 sway bars | SLP LM2 | Koni's | Ground Control 800/200 | Y2K wheels | Dyno Don headers & Y-pipe | airfoil | BBK underdrive pulleys | Raised strut mounts | Extended ball joints | LCARB'S
LB985IROC Member
Posted: Mon Oct 29, 2007 11:12 am Post subject: |
| fiveoformula wrote: | | LB985IROC wrote: | | okay new developement the plugs are missmatched between autrolites and bosch platinums....and the resistance on the wires is so out of wack that its causing the coil to over heat and thats what we are sure is causing the problme and i bought a fuel filter too for good measure |
dang... wonder what brilliant mind decided to do that... what plugs did you go with? |
AC delcos thats what i use in all my f-bodys _________________ Cadillac of Bellevue
Retail parts sales
LB985IROC Member
Posted: Mon Oct 29, 2007 11:14 am Post subject: |
| DBL_TKE wrote: | and here I was just about to ask if you were running Bosch plugs.  |
bosch plugs was my original thoughts
but none the less guys iot still dies but i know its not getting fuel because i can put my propane torch up to it and turn on the gas and the car will fire up but dies when the gas goes off so im not getting fuel and the injectors are pulsing i could hear them _________________ Cadillac of Bellevue
Retail parts sales
fiveoformula Member
Posted: Mon Oct 29, 2007 4:13 pm Post subject: |
delcos are good, pretty much anything accept bosch, i run NGKs, it purrs like a kitten _________________
'88 FORMULA |
Posted: Wed Oct 31, 2007 10:14 pm Post subject: |
Maybe you have a bad catalytic converter. Does it die when the car gets warmed up? _________________ Richmond 3.73 posi| 36/24 sway bars | SLP LM2 | Koni's | Ground Control 800/200 | Y2K wheels | Dyno Don headers & Y-pipe | airfoil | BBK underdrive pulleys | Raised strut mounts | Extended ball joints | LCARB'S
LB985IROC Member
Posted: Fri Nov 02, 2007 9:41 pm Post subject: |
CONFIRMED! IT WAS THE FUEL PUMP THE MOTOR WAS WEAK I WASNT GETTING EVEN ENOUGH FUEL PRESSURE oops...caplock lol anyways i replaced the pump and the harnes the old one was questionable and it runs way better and no dies in a 3 days and now you can hear it lol. oh and i also confirmed that the idea to cut a hole in the trunkc to get the module up will not work on our 4th gens the metal lines go all down the front and off the side i know you can with a 4th gen but i forgot about the metal lines on the thrid gen..... i cut the hole and everything.... but in the end i didnt have to drop the axle any just put it on stands amd the drop the exhaust and the head sheild and i jockied it out.... so it weasnt a total loss _________________ Cadillac of Bellevue
Retail parts sales
