92 tbi dies intermitantly
LB985IROC
1995 Chevrolet Camaro Z/28
PostPosted: Wed Oct 24, 2007 5:20 pm    Post subject: 92 tbi dies intermitantly Reply with quote
i juts got myself a nice 92 rs 305 tbi car and it dies intermitantly and wont restart for a few m ins and it dies again soon afterthe longer i let it sit and cool the longer it runs for its getting spark while it wont start and you can hear the pump buzzing after you let off bthe ignition when it wont start my replaced the ign coil and the ign module with no results
Cadillac of Bellevue
Retail parts sales
vee-six
PostPosted: Wed Oct 24, 2007 7:25 pm    Post subject: Reply with quote
how about when it runs, does it run crappy?
'88 FORMULA
LB985IROC
PostPosted: Wed Oct 24, 2007 7:44 pm    Post subject: Reply with quote
it seems to run alright and have good power but it idles kinda rough like it has a misfire
Retail parts sales
vee-six
PostPosted: Wed Oct 24, 2007 7:49 pm    Post subject: Reply with quote
Have you checked the fuel pressure at the rail?
PostPosted: Wed Oct 24, 2007 7:56 pm    Post subject: Reply with quote
Its TBI, there is no rail, and it is kind of a pain to check fuel pressure.
Have you done the normal tune up stuff? I would check the fuel filter, and give it new plugs/wires/cap/rotor, and also check the timing.
--John
PostPosted: Wed Oct 24, 2007 8:15 pm    Post subject: Reply with quote
Embarassed For some reason I read TPI. nm that...
LB985IROC
PostPosted: Wed Oct 24, 2007 8:19 pm    Post subject: Reply with quote
it has new cap and rotor old plugs and wires and not sure about the filter
Retail parts sales
vee-six
PostPosted: Wed Oct 24, 2007 8:34 pm    Post subject: Reply with quote
i was thinkin fuel filter. id start with that if you dont know the last time its been replaced, its like a 8 dollar part... if thats not it, plugs n wires
'88 FORMULA
LB985IROC
PostPosted: Thu Oct 25, 2007 5:00 pm    Post subject: Reply with quote
okay new developement the plugs are missmatched between autrolites and bosch platinums....and the resistance on the wires is so out of wack that its causing the coil to over heat and thats what we are sure is causing the problme and i bought a fuel filter too for good measure
Retail parts sales
vee-six
PostPosted: Fri Oct 26, 2007 9:27 pm    Post subject: Reply with quote
dang... wonder what brilliant mind decided to do that... what plugs did you go with?
'88 FORMULA
PostPosted: Sat Oct 27, 2007 1:53 am    Post subject: Reply with quote
and here I was just about to ask if you were running Bosch plugs. Rolling Eyes
LB985IROC
PostPosted: Mon Oct 29, 2007 11:12 am    Post subject: Reply with quote
AC delcos thats what i use in all my f-bodys
Retail parts sales
vee-six
LB985IROC
PostPosted: Mon Oct 29, 2007 11:14 am    Post subject: Reply with quote
bosch plugs was my original thoughts
but none the less guys iot still dies but i know its not getting fuel because i can put my propane torch up to it and turn on the gas and the car will fire up but dies when the gas goes off so im not getting fuel and the injectors are pulsing i could hear them
Retail parts sales
vee-six
PostPosted: Mon Oct 29, 2007 4:13 pm    Post subject: Reply with quote
delcos are good, pretty much anything accept bosch, i run NGKs, it purrs like a kitten
'88 FORMULA
PostPosted: Wed Oct 31, 2007 10:14 pm    Post subject: Reply with quote
Maybe you have a bad catalytic converter. Does it die when the car gets warmed up?
LB985IROC
PostPosted: Fri Nov 02, 2007 9:41 pm    Post subject: Reply with quote
CONFIRMED! IT WAS THE FUEL PUMP THE MOTOR WAS WEAK I WASNT GETTING EVEN ENOUGH FUEL PRESSURE oops...caplock lol anyways i replaced the pump and the harnes the old one was questionable and it runs way better and no dies in a 3 days and now you can hear it lol. oh and i also confirmed that the idea to cut a hole in the trunkc to get the module up will not work on our 4th gens the metal lines go all down the front and off the side i know you can with a 4th gen but i forgot about the metal lines on the thrid gen..... i cut the hole and everything.... but in the end i didnt have to drop the axle any just put it on stands amd the drop the exhaust and the head sheild and i jockied it out.... so it weasnt a total loss
Retail parts sales
vee-six
