Time to take a Break
J-Dog-III
PostPosted: Tue Sep 18, 2007 11:35 pm    Post subject: Time to take a Break Reply with quote
So recently my breaks have started squeaking and for a while when i break the car shudders. So i went and bought new brake pads and rotors and i was lookin through TGO and read the rotor sticky and i was wondering if it's really necessary to go through all the hassle of putting new bearings and everything else in?
I was hoping to take a couple hours this weekend and just get it done w/ but now it's looking like it's gonna take more time and money
PostPosted: Wed Sep 19, 2007 6:14 am    Post subject: Reply with quote
What the article on TGO say? I'd just check for bearing slop and at least repack them if not replace. Takes a few minutes per race to pound out. Or at you talking replacing rotors? Then, yeah, I'd slap some new bearings in there.
Sellmanb
PostPosted: Wed Sep 19, 2007 6:19 am    Post subject: Reply with quote
I'm w/ Ian. With new rotors it'd probably be a good idea to spend the 15 dollars or so for new inner and outer bearings. If you're on a real tight budget though, as long as the old bearings look OK, you can probably swap them over with no problems.
PostPosted: Wed Sep 19, 2007 1:32 pm    Post subject: Reply with quote
On a tight budget? The bearings are cheap in comparison to the rotors! I'd get new bearings cause its cheap and your there.
