Posted: Thu Sep 13, 2007 9:36 pm Post subject: |
[quote="DBL_TKE"] Quasi-Traction wrote: | DBL_TKE wrote: | I'll be there for sure, the track that is. Won't have time for pizza though, I have work from 5:30 to midnight. |
I might have to have you tech me. I don't think I'll pass otherwise.. |
I thought you passed last time? No problem though.
Breather is caughing up a significant amount of oil I"ll try to clean up before saturday, plus the fuel line issue they gave me a hard time for last time.
I need to fix my shock mount before Saturday. I lost the bolt and bent the pirch on the axle somewhere on the K-falls gathering/cruise. _________________
Posted: Thu Sep 13, 2007 9:38 pm Post subject: |
How the hell did you bend the bracket on the axle?! |
Posted: Thu Sep 13, 2007 9:44 pm Post subject: |
I dunno....I did notice about halfway home I heard a high pitched "ping" sound and there was a loud rattling sound from there on home....
Its not bad on the axle, I think vice grips and a propane torch and a trip to the JY and hardware store should solve the problem.
I think I'll go for the "jam nut" effect and grab two from the hardware store this time. _________________
Posted: Fri Sep 14, 2007 2:21 am Post subject: |
what is wrong with your fuel line? that may just be the most expensive part on the whole car! it is done ultra proffessional. what were they complaining about? |
Posted: Fri Sep 14, 2007 9:24 am Post subject: |
He probably has too long of a run of rubber line. |
Posted: Fri Sep 14, 2007 10:25 am Post subject: |
no thats what i am talking about. there is NO rubber line. chris and i went down to OFS and had a braided steel one made, it's all top nothch. braided steel from fuel pump to carb.
huh... from carb to tank though.... yeah, i bet there is rubber there. |
Posted: Fri Sep 14, 2007 11:56 am Post subject: |
Dewey316 wrote: | He probably has too long of a run of rubber line. |
7 Inches too much to be exact. As well as the oil leak. The guy who teched me last time was kind of cool about it, but he made a point that he probably shouldn't have let me pass.
Quote: |
no thats what i am talking about. there is NO rubber line........braided steel from fuel pump to carb. |
Where the hard lines come off the frame rail to the inlets for the fuel pump, there's rubber lines there. _________________
Posted: Fri Sep 14, 2007 2:43 pm Post subject: |
maximum amount of allowed rubberized fuel line is 12" so how are you too short? or are you saying that you have 21" of rubber line? _________________ Richmond 3.73 posi| 36/24 sway bars | SLP LM2 | Koni's | Ground Control 800/200 | Y2K wheels | Dyno Don headers & Y-pipe | airfoil | BBK underdrive pulleys | Raised strut mounts | Extended ball joints | LCARB'S
Posted: Fri Sep 14, 2007 5:08 pm Post subject: |
DBL_TKE wrote: | maximum amount of allowed rubberized fuel line is 12" so how are you too short? or are you saying that you have 21" of rubber line? |
I have about 20" of rubber line between the frame rail's hard line, to the pump. 10" on the inlet, 10" on the pressure return line. _________________
Posted: Sat Sep 15, 2007 11:26 am Post subject: |
I see. Was there anyone from the crew at PIR last night? There was a black IROC there that ran 15's and a gray camaro that ran 13's and was very clean, had some meaty tires in the back too. _________________ Richmond 3.73 posi| 36/24 sway bars | SLP LM2 | Koni's | Ground Control 800/200 | Y2K wheels | Dyno Don headers & Y-pipe | airfoil | BBK underdrive pulleys | Raised strut mounts | Extended ball joints | LCARB'S
