Posted: Tue Aug 21, 2007 6:15 pm Post subject: Random Chevy Garage Stuff |
I'm going to toss this stuff out if noone wants it! I have some more stuff, maybe I'll list it later.
Steering column - bad bearings, broken wiper lever, good switches and keys
Seat tracks - 2 pass/driver, 1 driver with tilt
Tranny cross member 4th gen auto
Brake master cylinders - 2ea
Exhaust tips - 4th gen rectangle, 2" pipe Twilight
Rear upper spring pads Twilight
LT1 engine mounting brackets
V6 EGR assy - non-digital
V6 coil bracket with coils - 2ea
V6 motor mounts Twilight
V6 bare block - no crank or caps BARE BLOCK
V6 Iron heads - Gen II Twilight
V6 harmonic balancer
V6 crank pulley - 2ea V-belt style triple belt
V6 engine lift bracket - one set Twilight
V6 starters - 2ea Twilight
V6 vacuum advance dizzy Twilight-Quazi
V6 valve covers, one set black, one gray
V6 T5 - cable slave for S10 (center mount shifter) twilight
*********UPDATED**************
rear carpet -1/2 gray. The piece covers the top of the tank hump and the back of the back seats. Picture on request
Headliner - 4th gen charcoal PERFECT
Elec Fan - single fan, 2ea Twilight
Door threshold - gray, passenger only
Wire harness - rear light harness, camaro
Cruise Module - 2ea
wiper assembly
hood latch cable - camaro
Kick panels - black, camaro
Hood hinges - white camaro
Dash- AC, 1986 says "Camaro" on passenger side
Center console - black, 5sp 2ea (one with gray boot) aaron_sk
Air Ducting - entire assy, AC
AC fan boxes - with fan, 3ea
E-brake assy
V6 starter (another one)
A-pillar cover, hardtop, 1set
Lower dual snorkle filter box aaron_sk
upper dual snorkle filter box 305 302eater
Brake Vacuum boxes - 2ea
ttop- passenger, pin style, tinted, glass, no key
115mph speedo - just speedo, no housing 16kmiles.
Tach - just tach, no housing, 5500 redline, no yellow.
and
(ATTENTION AL)
A gray (never been painted gray) spare tire rear cover with a non broken carpet locater! (I might bring this one for you anyway, Al has first dibs) _________________ E30
Posted: Tue Aug 21, 2007 10:58 pm Post subject: Re: Random Chevy Garage Stuff |
| blue89 wrote: |
V6 motor mounts
V6 starters - 2ea
Does that mean if you don't want it, it's free?! Maybe I could have one of the northern folks grab it and bring it down for the Southern Ore. Gathering. I forget exactly how far north you are. Might have to pay AL to meet you!
I'd be interested in the stuff above for the local "chevette" project.
Might want to pick your brain on your v6 motor too!
Do the Gen II heads fit Gen I? Aren't gen II heads supposed to be aluminum? |
Posted: Wed Aug 22, 2007 6:45 am Post subject: |
Ya, just as long as it dissappears. If not I'm TOSSING IT ALL! Muahahaha
There were two types of Iron heads for the V6. The GenII Iron had larger valves. In 86(?) chevy did a FWD aluminum head (GenI aluminum) and has done 2 more since then. Mainly what they upgraded was port design. And any 60V6 heads swap over to any block with the exception of the quad cam 3400. Check out the history at www.60degreeV6.com for more info.
I'm heading down this weekend to Poulsbo so if you want anything you better start coordinating! Al lives 10 miles south of my destination and I can meet him on Sunday afternoon. Do you want everything in the list? |
Posted: Wed Aug 22, 2007 8:03 am Post subject: |
I can do that. PM me for number and place to meet.  _________________ 92 Camaro
Posted: Wed Aug 22, 2007 8:54 am Post subject: |
I have more stuff too. I need to do an inventory of my upper shelf and my attic as well. The list will include a 4th gen dash, hood hinges, AC boxes, center consoles (one black no carpet, one gray carpet), gray hardtop visors, maybe some wiring.
If you guys were closer I'd just have an "open house" and you'd be free to browse around and take stuff (car stuff at least). |
Posted: Wed Aug 22, 2007 10:10 am Post subject: |
If you have an MPFI stuff laying around I'd go for that too!
Thanks AL!
Let me know if I can do anything for ya! |
Posted: Wed Aug 22, 2007 11:46 am Post subject: |
Are you after V6 stuff primarily? I could just load up anything I have and have you sort it out? Do you want the bar block?
I have a set of MPFI stuff but i want to keep it so I can still play with the V6 if I want to. Sorry. I do have fuel rails and 2.8 injectors though. I'll post more stuff tonight. |
Posted: Wed Aug 22, 2007 4:40 pm Post subject: |
Looking to put a MPFI 2.8 into a chevette. Don't know that I could use the bare block since I wont have pistons/crank/rods/caps etc.
Plus I don't want to overload AL too much :O)
So far Chris and I are thinking about picking up an s10 for the block/trans/suspension/rear and then getting the mpfi from a maro somehow. |
Posted: Wed Aug 22, 2007 5:05 pm Post subject: |
| I have everything to build a V6 except for the oil pan, crank, and caps. I even have a T5 for an S10! But ya, poor al. Lol. I have a TBI setup too. |
Posted: Wed Aug 22, 2007 6:33 pm Post subject: |
| blue89 wrote: | | I have everything to build a V6 except for the oil pan, crank, and caps. I even have a T5 for an S10! But ya, poor al. Lol. I have a TBI setup too. |
Well if you want to get rid of all of it, I'll certainly take it off your hands!
Think it would all fit in the back of a Wrangler or an '87 cavalier? It's got a pretty big trunk.
Are you taking the ferry or heading through tacoma? I may have sunday afternoon off.
I doubt al wants a 2.8 block in his car! lol
Could probably find a JY crank/pan/caps. For the chette it looks like a 4x4 pan would work best anyway. |
Posted: Wed Aug 22, 2007 6:47 pm Post subject: |
I updated the list (am after I type this).
If I were you, I would get a 3.1 crank/rods/piston and put that in the 2.8 block. Thats all you need to make a 3.1! But i don't know about dragging a block down that far. It would be a real killer if I had to brake fast and I'm taking the Tahoe down. Lets pass on this unless you want to pay gas then I'll trailer everything. |
Posted: Wed Aug 22, 2007 6:54 pm Post subject: |
Well, it might fit, but I have my subframe connectors (yet to be installed) in the back of the car. They don't take up a lot of room, but they do waste a lot of space for much else of any size to be put in there.  _________________ 92 Camaro
Posted: Wed Aug 22, 2007 7:00 pm Post subject: |
| blue89 wrote: | I updated the list (am after I type this).
3.1 is kind of what I'm thinkin of doing. See if I can squeeze out 100HP out of this ! LOL
As far as the chip goes and efi stuff... do I need stuff from the 3.1 years, will a 3.1 chip work in say an '87 ecm etc. I know nothing of the v6 stuff, but can tune and do all that with the v8 stuff.
If you still wanted to transport everything else from the v6 stuff and the list I cut: trans, tips, starter, etc and ad the electric fan in I could still meet ya.
I'll take the block too if you decide you want to haul it down. Should be able to secure it in the back. I've hauled several blocks in the back of my old s15 jimmys.
Just let me know! Kind of making this a semi crew project! Since I'm poor and this is going to be a goofy project for us down here. :O) |
Posted: Wed Aug 22, 2007 7:09 pm Post subject: |
Well then, we'll see. The problem is its a nice truck and I don't want greasy things in it
But just so YOU know, a 3.1RWD is hard to find, a 3.4RWD even harder. So what you do, is get a FWD 3.1 or 3.4 (easy to find) and put the crank and rods in a 2.8 block with new RWD 3.1 pistons. The FWD blocks have different motor mounts and the starters are on the other side.
Start a new thread so I can answer your V6 questions. |
Posted: Wed Aug 22, 2007 7:19 pm Post subject: |
Hijack FTW.
Back to the topic though, do you have any pics of the 5spd shifter consoles, and the dual snorkle box? |
kurfbird Member
Posted: Wed Aug 22, 2007 7:48 pm Post subject: I might be interested 2.8 block |
I might be interested 2.8 block _________________ kurfbird
1991 Camaro 3.1 v6
1991 Firebird 3.1 v6
1992 Formula 350 5.7
700r4 Transmissions
brucesthirdgenparts.com |
Posted: Wed Aug 22, 2007 9:10 pm Post subject: |
| I took pics of the consoles, dash, and intake. I'll post them tomorrow from work. Lol. Just standard parts though. The consoles have no carpet on them. Just plain black plastic. Looks like they need carpet, but they came that way from the factory. |
Posted: Wed Aug 22, 2007 10:34 pm Post subject: |
Do you only have the lower part of the console, or do you have the upper plate as well? I don't need the lower carpeted part.
I'm interested in pics of the airbox mainly to see if it's split apart like mine is. One of the brilliant previous owners deleted the silencer, and smashed the box into several pieces before putting it back. |
Posted: Thu Aug 23, 2007 6:51 am Post subject: |
Basic stuff. But no, i don't want to split the consoles, but if thats the only way you'll take it then fine. The dual snorkle is the lower box and upper. Should be all you need.
2 DAYS LEFT BEFORE THE AL TRANSFER STATION!
Oh ya, and one more item, 115mph speedo assy, just the speedo no housing. _________________ E30
Posted: Thu Aug 23, 2007 8:09 am Post subject: |
| If he only wants one console, I'll grab the other one. |
