miamivice Member
1982 Pontiac Trans Am
Posted: Sun Jun 20, 2004 4:55 pm Post subject: LCA relocation brackets? |
im getting ready to order SFC from spohn for my 87. i was reading their descrpitons on some of the other parts and saw these brackets. my car is not lowered, but i do have crappy traction and bad wheel hop. would it solve my problems? also, would i also need to get new LCAs or can i use my stock ones (until i get more $$$).
what ya'll think?
thanks _________________
Posted: Mon Jun 21, 2004 3:20 am Post subject: |
they should help. what you need to do, is look at where your LCA's are sitting now. if the body side of the LCA is higher than the axle side, you need brackets. and yes you can use your stock stock LCA's with the brackets.
Posted: Mon Jun 21, 2004 12:25 pm Post subject: |
| Dewey316 wrote: | they should help. what you need to do, is look at where your LCA's are sitting now. if the body side of the LCA is higher than the axle side, you need brackets. and yes you can use your stock stock LCA's with the brackets.
Strike that Dewey, if the body side mount of the LCA(Towards the front of the car) is higher than the rear end mount, you're good. If it's level you are good. If the body is LOWER than the rear end, then get the brackets. |
Posted: Mon Jun 21, 2004 1:07 pm Post subject: |
| err, it was 4 in the A.M. |
Posted: Mon Jun 21, 2004 5:36 pm Post subject: |
| Dewey316 wrote: | | err, it was 4 in the A.M. |  |
miamivice Member
Posted: Mon Jun 21, 2004 9:02 pm Post subject: |
ok thanks guys......one more question about the brackets. when they are welded in, do they only go in one way or can they be put in at diffrent angles? cause, eventualy if i get the spohn control arms or something (adjustable????) id like to make sure i they will fit in there _________________
Posted: Tue Jun 22, 2004 3:35 am Post subject: |
its pretty hard to mess up.  |
