Posted: Wed Jun 13, 2007 3:27 pm Post subject: Starting from scratch |
K, I started with the stock azty.bin (1991 3.1L) and made the following changes. Does that look okay?
Edit Log for V6program_02.bin created by TunerPro.
06/13/2007 16:09:43 Constant: Fuel Cutoff Vehicle Speed changed from 115.00 MPH (0x73) to 255.00 MPH (0xFF).
06/13/2007 16:09:54 Constant: Fuel Resume Vehicle Speed changed from 112.00 MPH (0x70) to 247.00 MPH (0xF7).
06/13/2007 16:10:29 Constant: Idle RPM Offset for A/C On changed from 100.00 RPM (0x08) to 0.00 RPM (0x00).
06/13/2007 16:11:07 Constant: A.I.R. Enable Coolant Temp. Threshold changed from 16.25 Deg. C (0x4B) to 151.25 Deg. C (0xFF).
06/13/2007 16:12:09 Constant: Fan 1 On Coolant Temp, Low MPH, A/C Off changed from 107.75 Deg. C (0xC5) to 86.75 Deg. C (0xA9).
06/13/2007 16:12:13 Constant: Fan 1 On Coolant Temp, Hi MPH or A/C On changed from 106.25 Deg. C (0xC3) to 86.75 Deg. C (0xA9).
06/13/2007 16:12:26 Constant: Fan 1 Off Coolant Temp, Low MPH, A/C Off changed from 104.00 Deg. C (0xC0) to 82.25 Deg. C (0xA3).
06/13/2007 16:12:33 Constant: Fan 1 Off Coolant Temp, Hi MPH or A/C On changed from 101.75 Deg. C (0xBD) to 82.25 Deg. C (0xA3).
06/13/2007 16:13:12 Constant: Maximum Time in Launch Mode changed from 2.00 sec (0xA0) to 3.19 sec (0xFF).
06/13/2007 16:13:49 Constant: Fuel Cutoff RPM changed from 6212.00 RPM (0x00D3) to 7009.26 RPM (0x00BB).
06/13/2007 16:13:57 Constant: Fuel Resume RPM changed from 5985.08 RPM (0x00DB) to 6791.36 RPM (0x00C1).
06/13/2007 16:14:20 Constant: EGR Enable Min Coolant Temp changed from 38.00 Deg. C (0x68) to 151.25 Deg. C (0xFF).
06/13/2007 16:15:19 Constant: Max Vehicle Speed for Idle changed from 3.00 MPH (0x09) to 14.67 MPH (0x2C).
06/13/2007 16:17:17 Constant: Road Speed Constant changed from 4004.78 Pulses/Mi (0x0731) to 4806.26 Pulses/Mi (0x05FE).
06/13/2007 16:17:47 Flag: Lean Cruise Option (X = active) changed from Not Set to Set.. |
Posted: Wed Jun 13, 2007 4:43 pm Post subject: Re: Starting from scratch |
| blue89 wrote: | 06/13/2007 16:15:19 Constant: Max Vehicle Speed for Idle changed from 3.00 MPH (0x09) to 14.67 MPH (0x2C).
sweet. a little economy mixed in there. |
Posted: Wed Jun 13, 2007 9:35 pm Post subject: |
I turned up the closed loop min temp to 153*. I'm now working on getting the open loop AFR down. Right now the o2 says its running .200V lean. Still smells way rich. Idle is 600RPM and 60kPA, open loop.
Things I will modify
Main Volumetric Efficiency Vs RPM Vs MAP
Closed Throttle Open Loop AFR Vs Coolant Temp
Idle Volumetric Efficiency Vs RPM Vs MAP
Open Loop AFR Vs Coolant Temp Vs MAP |
Posted: Wed Jun 13, 2007 10:59 pm Post subject: |
Watch the lean cruise stuff. Sometimes it can make you WAY to lean. In some masks there is a highway spark mode. Which can add too much timing.
I found both these out when I first enabled mine back in the day. It would run the motor so lean the o2 SES light would come on under cruise. |
Posted: Sat Jun 16, 2007 2:26 pm Post subject: |
Could someone with a cam that idles at 45-60kPA please show/send me a copy of the VE tables for idle. I'm having a very hard time getting this system to idle right.
It idles okay at 55-60kPA at .220V on the o2, but any amount of throttle, even the TINIEST crack, and it jumps up to 2000rpm. Stock program or modified, I just can't get it to be better. Thanks. |
