Cold start injector removal update
MIDNITERIDER
New Member
PostPosted: Sat Mar 24, 2007 6:08 am    Post subject: Cold start injector removal update Reply with quote
Last weekend pulled the 9th injector cold start and fuel line and put in the Accel block off kit. Started it up today...cranked over first time and to my amazement NO typical puff of black smoke. My car has just turned 50,000 miles and for years had this annoying problem. All thought that it was the typical "valve seal" thing. I also noticed that when I increased the rpm while it was cold; no crackling in the exhaust sound or mini backfires(only happened when cold on start up). Very interesting that GM eliminated the cold start injector in 1989...coincidence??? makes me wonder...!!!!!!
1988 Formula 350
13.93 @ 99.32mph
PostPosted: Sat Mar 24, 2007 6:12 am    Post subject: Reply with quote
Thats good to hear. Did you update the computer to newer code?
MIDNITERIDER
New Member
PostPosted: Sat Mar 24, 2007 6:18 am    Post subject: Reply with quote
No...the MRP e prom I installed in 1989 has worked well for me and I have been pleased with its window of adjustment for variances..
1988 Formula 350
13.93 @ 99.32mph
PostPosted: Sat Mar 24, 2007 2:02 pm    Post subject: Reply with quote
The valve seals will be a puff of blue burnt oil. Black puffs are fuel.
When GM eliminated the cold start injector, they richened up the tune in the computer chip to compensate.
PostPosted: Sat Mar 24, 2007 3:06 pm    Post subject: Reply with quote
What is an MRP eprom? I know what an eprom is but haven't heard of MRP.
MIDNITERIDER
New Member
PostPosted: Sat Mar 24, 2007 5:25 pm    Post subject: Reply with quote
Sorry; their name now is Performance Resource...back in '89 there were many write ups in several magazines about them and other manufacturers and they won hands down in all catagories when they ran tests and comparisons ...their e prom was the best at the time...
1988 Formula 350
13.93 @ 99.32mph
MIDNITERIDER
New Member
PostPosted: Sat Mar 24, 2007 5:33 pm    Post subject: Reply with quote
The colour is bluish black...and I agree with you...always felt it was fuel related but didnt know how to tackle the problem..everyone was pointing to the seals. I feel it should be okay without the extra '89 enrichment. I only run in the summer and let it sit for a week and tried it today and started on the first crank..it was 40*F here today when I started it.
1988 Formula 350
13.93 @ 99.32mph
PostPosted: Sat Mar 24, 2007 5:48 pm    Post subject: Reply with quote
gotcha - thanks!
dlp
1990 Chevrolet Camaro IROC-Z
PostPosted: Fri Mar 30, 2007 6:27 pm    Post subject: Reply with quote
The 9nth injector can be removed, just need a chip burned to mantain cold start quick starts. I ran into this dilema when I installed a T-Ram on my 87, no boss for the cold start injector. Ed Wright burned my chip, no cold start issues.
