ALDL dataloging cable.
PostPosted: Wed Mar 14, 2007 9:18 pm    Post subject: ALDL dataloging cable. Reply with quote
hey Paul..
i finaly got around to making that data cable, and i have no idea what this diagram means...
i get the 4/9 2/9, those are the positions on the Serial cable. what i need to know, is which pins on the transistors (they are labled I I T). which way do the resistors go? do they both resist the flow toward the PC?
thanks alot. Smile
PostPosted: Wed Mar 14, 2007 10:56 pm    Post subject: Reply with quote
Transistors should be labeled on the back of the packages as Base/Emitter/Collector.
The Base is the line in the middle of the circle that goes straight to the middle of the bold line within the circle.
The Emitter is the lead with the Arrow (out)
The Collector is the lead without the arrow (in)
Resistors can go either way.
PostPosted: Wed Mar 14, 2007 11:03 pm    Post subject: Reply with quote
they did not come in a package... i got them from the guy at the counter Confused
i'll test the resistors to be sure, i know some resistors are one way.
EDIT*
found a thing on line... shows the pins. Smile
PostPosted: Thu Mar 15, 2007 10:18 am    Post subject: Reply with quote
Resistors are not one way. Diodes are one way.
PostPosted: Thu Mar 15, 2007 11:05 am    Post subject: Reply with quote
oh yea....
got it all together and looking awsome, but norvac sold me the wrong size shell for my serial connector, so i can't finish it up yet...
PostPosted: Thu Mar 15, 2007 11:24 pm    Post subject: Reply with quote
hey, what program do i download to do the datalogging? and the view my ECU output in real time?
PostPosted: Fri Mar 16, 2007 3:01 pm    Post subject: Reply with quote
downloaded craig moates software... DOS Rolling Eyes
anyway, i can't get the cable to connect, but i don't know how to setup the serial port so there is realy no surpirse there. but i was surprised by one thing....
when i put the cable on the six, and flip the switch (to ground A/B) the ECM light blinks the codes, which is exactly what it is suposed to do. when i do the same thing in the GTA it turns the cooling fan on, and the ECM light goes off. WTF?
also how do i set up the serial port?
PostPosted: Fri Mar 16, 2007 4:45 pm    Post subject: Reply with quote
It's not supposed to make the SES blink. What it does on the GTA is normal.
I don't know that you are supposed to jumper with a 10k ohm for hte 2.8. Different ECM.
PostPosted: Fri Mar 16, 2007 4:59 pm    Post subject: Reply with quote
oh ok good.
why did the diagram call for a switch to make the fan come on?
PostPosted: Fri Mar 16, 2007 5:45 pm    Post subject: Reply with quote
The ECM triggers the fan for whatever diagnostic reason.
The Switch is to tell the ECM to go into "spit out data mode."
PostPosted: Fri Mar 16, 2007 10:53 pm    Post subject: Reply with quote
ahh... so i need to bridge different ports on the six to put it on "spit out data" mode.
i was reading somthing on TGO that said NOT to turn the car on when ports a/b are connected. is that true or false?
