3rd gen steering column
PostPosted: Thu Mar 15, 2007 7:30 am    Post subject: 3rd gen steering column Reply with quote
I'm headed down to Bremerton for an Autocross this weekend and need a new column for my 89 LT1. Tilt would be great, but not needed. It has no cruise, but int. wipers. I'll be swapping out the key cylinder so you don't need the keys. But I'll take them if you have them. VATS has been bypassed already.
The original column had the bearing grenaded. i have no idea how the previous owner did it, but both the inner and outer bearings in the tilt are missing balls, bearing keeps were cracked and broken. I found enough bearing balls to make the outer bearing stay still, but the inner one is almost missing. It drives fine, but has some slop, as you would imagine.
So if anyone has one I'd buy one this weekend while I'm down south since noone lives as north as me except for droptop.
Thanks!
-t
Demon
PostPosted: Thu Mar 15, 2007 8:24 am    Post subject: Reply with quote
I've got one at my mothers house in Monroe if you want to make the drive... it's just sitting in the rafters ... its a tilt wheel column with wheel from an 83 Z28 ... not sure how good the connectors are on it but I believe you can swap those if need be. You can just leave my mom 20 bucks or something and its yours haha...
no idea if you want to make the trek out there or not though
kurfbird
PostPosted: Thu Mar 15, 2007 9:21 am    Post subject: Column Reply with quote
I have a column no tilt. Has high and low wipers. I live on whidbey island. I dont have a key but its not put in yet. Seems farily tight. Maybe a litle up and down movement. but not excessive. Asking 30.00
I live on whidbey Island
kurfbird
1991 Camaro 3.1 v6
1991 Firebird 3.1 v6
1992 Formula 350 5.7
700r4 Transmissions
brucesthirdgenparts.com
PostPosted: Thu Mar 15, 2007 9:51 am    Post subject: Reply with quote
Monroe is a bit out of the way.
It doesn't have int wipers, just hi/low/off? If its something like 1/4" of play I can't use it. Autocross Tech inspectors will catch something like and won't let you race if it has excessive slop.
Demon
PostPosted: Thu Mar 15, 2007 10:21 am    Post subject: Reply with quote
its been awhile but I believe its got intermitent... and no slop when I pulled it
kurfbird
PostPosted: Thu Mar 15, 2007 10:29 am    Post subject: play Reply with quote
has less than a quater inch. Has high low and off on the wipers. Come take it look its still on the car. You can judge for yourself.
kurfbird
1991 Camaro 3.1 v6
700r4 Transmissions
PostPosted: Mon Mar 26, 2007 11:11 am    Post subject: Reply with quote
hey kurfbird, still got that column? I may try to come down this weekend to Whidbey to get it if you don't mind. You mentioned that it was still installed?
kurfbird
PostPosted: Mon Mar 26, 2007 11:14 am    Post subject: Coplumn Reply with quote
Yes I still have it. And still installed. will Pm you my address.
kurfbird
1991 Camaro 3.1 v6
700r4 Transmissions
