The Ten Basic Laws of Cartoon Physics
PostPosted: Thu Jan 11, 2007 7:53 pm    Post subject: The Ten Basic Laws of Cartoon Physics Reply with quote
Physics in the cartoon world:
Cartoon Law I
Any body suspended in space will remain in space until made aware of its situation.
Daffy Duck steps off a cliff, expecting further pastureland. He loiters in midair, soliloquizing flippantly, until he chances to look down. At this point, the familiar principle of 32 feet per second takes over.
Cartoon Law II
Any body in motion will tend to remain in motion until solid matter intervenes suddenly.
Whether shot from a cannon or in hot pursuit on foot, cartoon characters are so absolute in their momentum that only a telephone pole or an outsize boulder retards their forward motion absolutely. Sir Isaac Newton called this sudden termination of motion the stooge's surcease.
Cartoon Law III
Any body passing through solid matter will leave a perforation conforming to its perimeter.
Also called the silhouette of passage, this phenomenon is the speciality of victims of directed-pressure explosions and of reckless cowards who are so eager to escape that they exit directly through the wall of a house, leaving a cookie-cutout-perfect hole. The threat of skunks or matrimony often catalyzes this reaction.
Cartoon Law IV
The time required for an object to fall twenty stories is greater than or equal to the time it takes for whoever knocked it off the ledge to spiral down twenty flights to attempt to capture it unbroken.
Such an object is inevitably priceless, the attempt to capture it inevitably unsuccessful.
Cartoon Law V
All principles of gravity are negated by fear.
Psychic forces are sufficient in most bodies for a shock to propel them directly away from the earth's surface. A spooky noise or an adversary's signature sound will induce motion upward, usually to the cradle of a chandelier, a treetop, or the crest of a flagpole. The feet of a character who is running or the wheels of a speeding auto need never touch the ground, especially when in flight.
Cartoon Law VI
As speed increases, objects can be in several places at once.
This is particularly true of tooth-and-claw fights, in which a character's head may be glimpsed emerging from the cloud of altercation at several places simultaneously. This effect is common as well among bodies that are spinning or being throttled. A `wacky' character has the option of self- replication only at manic high speeds and may ricochet off walls to achieve the velocity required.
Cartoon Law VII
Certain bodies can pass through solid walls painted to resemble tunnel entrances; others cannot.
This trompe l'oeil inconsistency has baffled generations, but at least it is known that whoever paints an entrance on a wall's surface to trick an opponent will be unable to pursue him into this theoretical space. The painter is flattened against the wall when he attempts to follow into the painting.
This is ultimately a problem of art, not of science.
Cartoon Law VIII
Any violent rearrangement of feline matter is impermanent.
Cartoon cats possess even more deaths than the traditional nine lives might comfortably afford. They can be decimated, spliced, splayed, accordion-pleated, spindled, or disassembled, but they cannot be destroyed. After a few moments of blinking self pity, they reinflate, elongate, snap back, or solidify.
Corollary: A cat will assume the shape of its container.
Cartoon Law IX
Everything falls faster than an anvil.
Cartoon Law X
For every vengeance there is an equal and opposite revengeance.
This is the one law of animated cartoon motion that also applies to the physical world at large. For that reason, we need the relief of watching it happen to a duck instead.
Cartoon Law Amendment A
A sharp object will always propel a character upward.
When poked (usually in the buttocks) with a sharp object (usually a pin), a character will defy gravity by shooting straight up, with great velocity.
Cartoon Law Amendment B
The laws of object permanence are nullified for "cool" characters.
Characters who are intended to be "cool" can make previously nonexistent objects appear from behind their backs at will. For instance, the Road Runner can materialize signs to express himself without speaking.
Cartoon Law Amendment C
Explosive weapons cannot cause fatal injuries.
They merely turn characters temporarily black and smoky.
Cartoon Law Amendment D
Gravity is transmitted by slow-moving waves of large wavelengths.
Their operation can be witnessed by observing the behavior of a canine suspended over a large vertical drop. Its feet will begin to fall first, causing its legs to stretch. As the wave reaches its torso, that part will begin to fall, causing the neck to stretch. As the head begins to fall, tension is released and the canine will resume its regular proportions until such time as it strikes the ground.
Cartoon Law Amendment E
Dynamite is spontaneously generated in "C-spaces" (spaces in which cartoon laws hold).
The process is analogous to steady-state theories of the universe which postulated that the tensions involved in maintaining a space would cause the creation of hydrogen from nothing. Dynamite quanta are quite large (stick sized) and unstable (lit). Such quanta are attracted to psychic forces generated by feelings of distress in "cool" characters (see Amendment B, which may be a special case of this law), who are able to use said quanta to their advantage. One may imagine C-spaces where all matter and energy result from primal masses of dynamite exploding. A big bang indeed.
Very Happy
PostPosted: Thu Jan 11, 2007 9:11 pm    Post subject: Reply with quote
Sweet, gonna have to email that one to Mom. Laughing
PostPosted: Thu Jan 11, 2007 9:40 pm    Post subject: Re: The Ten Basic Laws of Cartoon Physics Reply with quote
Schultzy89GTA wrote:
Cartoon Law I
The rate of gravity is 32 feet per second squared, or 32 feet per second per second. Very Happy I seem to remember this from my Navy days. Laughing Gravity = acceleration, acceleration = change in speed.
Daffy will accelerate at the rate of gravity either until he reaches terminal velocity or reaches the base of the cliff, at which time he experiences sudden deceleration syndrome Laughing
PostPosted: Sun Jan 14, 2007 8:45 pm    Post subject: Reply with quote
oh man, I miss the old cartoons! Warner Bros cartoons and The Muppet Show.
Demon
PostPosted: Sun Jan 14, 2007 9:24 pm    Post subject: Reply with quote
the muppet show wasn't a cartoon Surprised neither was sesame street or fraggles...
puppets are great
PostPosted: Sun Jan 14, 2007 10:36 pm    Post subject: Reply with quote
Hey, what about the Scooby Doo effect?! You know, the one in which when a scared character begins to run, his legs resemble a fast moving wheel and he will hover in place for a moment before finally accelerating! Razz
