header collector bolts, loose again
scott in wa.
1988 Chevrolet Camaro IROC-Z
PostPosted: Thu Jan 11, 2007 6:06 am    Post subject: header collector bolts, loose again Reply with quote
Well, this is about the 6th time we have had to jack up the car and try and tighten these three bolts on each header collector, its a big pain.
How do you guys keep them tight? special bolts???
Iam running the shorty headers with the socket type connection.
Tried lock washer, nada
Tried loctite nada.
How about those Crush type nuts??
So how do you keep these tight???'
thanks
scott
PostPosted: Thu Jan 11, 2007 8:35 am    Post subject: Reply with quote
I used two nuts on each bolt. Tighten one up where you want it then run the second nut up to the first. Then two wrenches and turn the top nut back a little while tightening the bottom. Kinda tighten the two into each other.
PostPosted: Thu Jan 11, 2007 9:17 am    Post subject: Reply with quote
Two Words:
Lock-Washer
PostPosted: Thu Jan 11, 2007 9:45 am    Post subject: Reply with quote
Hmm.... I guess there is an upside to having headers with really crappy paint on them, since the rust seems to always keep my bolts well in place. Embarassed
PostPosted: Thu Jan 11, 2007 12:38 pm    Post subject: Reply with quote
Two Words: Lock-Washer
the two nuts thing seems to work prety well, i use two nuts for alot of things. Shocked in all seriousness i think that should work. think about the brake adjustment on most cars, two nuts.
PostPosted: Thu Jan 11, 2007 2:10 pm    Post subject: Reply with quote
Can't we keep anything clean around here. Rolling Eyes
PostPosted: Thu Jan 11, 2007 4:10 pm    Post subject: Reply with quote
who are we kidding Wiggly wiggly
PostPosted: Thu Jan 11, 2007 11:51 pm    Post subject: Reply with quote
i ment automotive projects, come on rod, get your mind out of the gutter, don't try to force your immaturity on me. Razz
PostPosted: Fri Jan 12, 2007 12:12 am    Post subject: Reply with quote
I use stainless steel bolts and lock washers and never have to re-tighten.
PostPosted: Sun Jan 14, 2007 7:19 pm    Post subject: Reply with quote
The problem i had with the bolts on the collectors i was using grade 5 nuts and bolts grade 5 can't take the high exhaust temperature( they expand and contract too much to make the hold) my options were to use grade 8's or aircraft grade bolts they can definitly handle the temp. so i opted for the grade 8's(nuts bolts and lock washers) and never had a problem since. p.s. don't use lock tight they'll burn off and you'll have to retorque them again.
