Nathan J Member
1986 Pontiac Firebird
Posted: Sat Jan 06, 2007 10:29 pm Post subject: bah rant |
Well bad bad bad weekend so far lol, plans where to test fire the engine this weekend and that was stoped very fast. looks as though i got by info from my engine build and now I need to pull the engine back out of the car, mess with getting 1 intake bolt out for a hour since my fogger is in the way then take the heads off and the pan and yes flip all of my pistons on the rods since the reliefs are facing down not up and right now every valve hits the pistons so ya bad bad weekend so far lol. but whiles it out ill put all my new susp on the car and im junking the brand new hyd cam in the engine now and going bigger and mech roller so im trying to look at this the best i can but darn it its a pain to pull that engine lol.
end of rant
Nathan _________________ 86 firebird
383sbc
th350 t brake
4th gen rear soon 9in ford rear |
Magman 11sec Club
Joined: 02 Apr 2005 Posts: 217 Location: Whidbey Island
1990 Chevrolet Camaro IROC-Z
Posted: Sat Jan 06, 2007 11:07 pm Post subject: |
That sucks man. Building it twice is never fun. Similar instance here with my 383. The balance shop screwed me hardcore. They ended up paying $250 towards gaskets and bearings and polishing the crank. So you're definately not alone! _________________ 1990 IROC-Z, 383 HSR, 3.70 9-Bolt
383 RWHP / 372 TQ
11.78 @ 115 w/1.59 60' (8-18-2012) |
Posted: Sat Jan 06, 2007 11:33 pm Post subject: |
That is nasty Nathan. Hey at least you caught it before major damage was done right? (I really hope that is right).
Why the cam swap?
Posted: Sun Jan 07, 2007 8:10 am Post subject: |
Well if he thinks like me, no car repair is complete without an upgrade. It makes the whole job much more tolerable to have something to look forward to. Otherwise... it's just plain work.  |
Posted: Sun Jan 07, 2007 9:45 am Post subject: |
ahhh and I would be quick to agree. I was just assuming that the cam was chosen for the new engine as part of an overall plan and was curious why you would change up the plan before being able to see how it panned out.
Nathan J Member
Posted: Sun Jan 07, 2007 12:51 pm Post subject: |
ya no major damage was done thank god lol. I wanted to go roller in the first place but didnt have the money and went cheap on a off the shelf hyd flat tappet. its not really perfect for the engine but its not to bad but the rpms i plan on spinning it to a hyd flat tappet is not my best choice. plus it seems about a 50 50 change of wiping a lobe on a flat tappet cam and if im taken this engine out i want to put the roller in and i dont have to worry about taken the motor out again to clean metal out of it lol. plus like said above it gives me somethen to look forward to lol.
383sbc
th350 t brake
Posted: Sun Jan 07, 2007 1:55 pm Post subject: |
cool
What cam are you going with?
Nathan J Member
Posted: Sun Jan 07, 2007 8:15 pm Post subject: |
im going to get ahold of a few more companys but a custom grind mech roller, most of the rollers do not have very good lobe seperation, i want a little more for the nitrous but somewhere in the .610int .620exh on atleast a 110 lobe sep but would like 112. so its new valve springs new roller lifters and new cam going to cost about 700 or so maybe alittle more to much but o well _________________ 86 firebird
383sbc
th350 t brake
izcain 9sec Club
Posted: Sun Jan 07, 2007 8:42 pm Post subject: |
Im not trying to be sound like an @ss or anything but didn't you turn the motor over before you went thru the hassle of installing it in the car? Or did you build most of it in the car? Thats a bummer all the same, I hate having to do something twice when I didn't even get to enjoy it the first time! What hydraulic cam did you go with in the beginning? _________________
9.17 @ 148 |
Nathan J Member
Posted: Sun Jan 07, 2007 10:24 pm Post subject: |
I turned it over lots with the heads on, but being dumb I never adj the rockers and did a test turn it was a mistake on my part but o well. it has a .533int .555exh 114deg lobe sep and 312 deg of adv duration in it now _________________ 86 firebird
383sbc
th350 t brake
izcain 9sec Club
Posted: Mon Jan 08, 2007 12:37 am Post subject: |
Oh that sucks man! sounds like that cam you have in there would make a really nice one for someone runnin gas. _________________
9.17 @ 148 |
