scott in wa. Member
1988 Chevrolet Camaro IROC-Z
Posted: Tue Nov 21, 2006 12:15 pm Post subject: Convertible A pillar gage pod |
So will all the gage pods fit on a vert??? Or are they different???
Can’t seem to find any that are vert only.
Scott |
scott in wa. Member
Posted: Tue Nov 21, 2006 12:49 pm Post subject: sweet |
good stuff.
thanks |
Posted: Tue Nov 21, 2006 10:10 pm Post subject: |
FYI; a vert's a-pillar plastic is the same as a t-tops with the top cut off. _________________
90droptoproc Member
Posted: Wed Nov 22, 2006 12:16 am Post subject: |
| iansane wrote: | | FYI; a vert's a-pillar plastic is the same as a t-tops with the top cut off. |
I second this, you should be fine with either a pod for your stock pillar or a whole new pillar with pods already molded in, but you will need to cut the top off to match your old one _________________
