82camaro383 12sec Club
Joined: 11 Sep 2005 Posts: 117 Location: Pullman/Vancouver, WA
Posted: Sun Mar 19, 2006 9:57 am Post subject: Duel Exhaust |
I'm just about to put my 383 in my z28, so ihave started thinking about the exhaust. I want long tube headers with pipes going straight to the back of the car. I don't want to run any cats or have on an H or X pipe. Would something like this work? _________________ 85 Z28, 383 Stroker, TH350 tranny, Richmond 4.10 gears, dual exhaust
Fastest Time: 12.7sec @ 107mph |
Posted: Sun Mar 19, 2006 11:25 am Post subject: |
Been done many times. Running long tubes is a perfect time for the benefits of an X pipe.
Loud as snot.
Unless you find a way to get the drivers side over/under the rear axle to have a rear exit. |
Posted: Sun Mar 19, 2006 12:13 pm Post subject: |
I read once that having an X pipe is a good thing, as it equalizes pressure in both exhaust banks, so you dont have any kind of "popping" when you take your foot off the petal from WOT. _________________
Posted: Sun Mar 19, 2006 4:12 pm Post subject: |
Running an X pipe is a bad idea on shorties. The problem with shorties, is that they are not equal length to each other and you can have exhaust pulses crash into each other rather than work as a syphon.
Long Tube headers are Ideal for an xpipe. |
