Spohn LCA Brackets
PostPosted: Tue Feb 10, 2004 8:57 pm    Post subject: Spohn LCA Brackets Reply with quote
NEW IN BOX.
i'm getting some from the head cheez. selling the spohns.
wolfman had originaly said he wanted them, but i never heard anything more from his, so they are back up here.
the first $50 takes them. if you need them shipped, you pick up the coin for that too (i know, i know)
Wolffy
PostPosted: Wed Feb 11, 2004 8:03 am    Post subject: Reply with quote
sorry Dewster, ive been busy the last 3 weeks trying to find a job in this forsaken town, there are none & the few that do open up get filled in the first day.
ill still take them deswster
please im or email me your addy & ill send ya some $$$$
wolffman007@yahoo.com
J96Z
New Member
PostPosted: Sun Feb 15, 2004 12:41 pm    Post subject: Reply with quote
If you stiil have them and they are the ones for the stock rearend, Ill take them. I'm in Puyallup. Let me know.
Merle
PostPosted: Mon Feb 16, 2004 4:12 am    Post subject: Reply with quote
Merle,
Wolfman already got ahold of me again, he is sending money out for them.
Sorry.
J96Z
New Member
PostPosted: Mon Feb 16, 2004 9:41 am    Post subject: Reply with quote
Well if it falls through by any chance please keep me in mind. Thanks.
Merle
PostPosted: Mon Feb 16, 2004 9:49 am    Post subject: Reply with quote
will do!
Midnight Sun
PostPosted: Mon Feb 16, 2004 10:38 am    Post subject: Reply with quote
Hey Merle, if you really need some LCA brackets I am pretty sure Mr Cheez sells them.
When I was up at his place he showed me one of prototypes, I think he said he was gonna start selling them.
J96Z
New Member
PostPosted: Mon Feb 16, 2004 10:59 am    Post subject: Reply with quote
I sure do need some. I'm gonna need someone to weld them on for me too. How much is he selling his for and are they as good or better then the Spohns?
PostPosted: Mon Feb 16, 2004 11:46 am    Post subject: Reply with quote
they are better than spohns, i am selling mine and putting his on.
right now he isn't selling them, mine will be set #2, and i beleive we are going to make sure they work, and fit both our cars and last a bit before he sells them. you might want to check with him though.
J96Z
New Member
PostPosted: Mon Feb 16, 2004 12:19 pm    Post subject: Reply with quote
How do I contact him?
PostPosted: Mon Feb 16, 2004 12:27 pm    Post subject: Reply with quote
click on memberlist at the top, and hit PM next to CheezX
or i beleive his email is
mike@blackbirdindustries.com
J96Z
New Member
PostPosted: Mon Feb 16, 2004 12:37 pm    Post subject: Reply with quote
thanks. I just emailed him.
Midnight Sun
PostPosted: Mon Feb 16, 2004 1:22 pm    Post subject: Reply with quote
Well... I know what they do.. (idiot eric time)
But why would you need to relocate your control arms?
PostPosted: Mon Feb 16, 2004 1:24 pm    Post subject: Reply with quote
to get better rear geometry, it aids in traction. it all comes down to the anti-squate properties, with the right geomety it drives the rear into the ground, instead of away from the ground. this is especialy needed if you car has been lowered, you need the brackets to even get back to the stock setting.
Midnight Sun
PostPosted: Mon Feb 16, 2004 1:25 pm    Post subject: Reply with quote
So they basically do what traction bars would? To a minor degree at least?
PostPosted: Mon Feb 16, 2004 1:27 pm    Post subject: Reply with quote
in some ways, but traction bars are to control leaf spring rears, this has to with the the way the parts move as torque is applied.
J96Z
New Member
PostPosted: Mon Feb 16, 2004 1:33 pm    Post subject: Reply with quote
I lowered my car and when you do that it puts the control arm at a different angle and makes the car get wheel hop. The brackets put the lower control arm back in the correct angle when the car is lowered. The control arm is supposed to be parallel with the ground or maybe sloping down towards the rear a little. When the car is lowered, they slope up towards the rear and causes wheel hop.
CheezX
PostPosted: Tue Feb 17, 2004 12:59 am    Post subject: Reply with quote
Woah! Thought this post was about Spohn stuff! Shocked
Here's what Dewey is talking about. Not exactly for sale yet but if Dewey's set works out well then they will be. The first set made (which Eric saw) is on my car already which is lowered 3" (can stick 2 fingers in the gap). The bottom hole lowers 3.25". I've had them on about 2 months and they're doing fine, and no I do not baby the car. Twisted Evil
Computer engineered, laser cut, and powdercoated. 50% lighter than Spohn's yet good to 900 ft-lbs of torque(try hooking that up on a 10-bolt) assuming 3.42 rear with 2.95 1st gear ratios. Good stuff!
John, I got the precision jig stuff made. Parts are going to the welder on Wed, then off to powdercoat. The much too long wait is almost over. Cool
PostPosted: Tue Feb 17, 2004 4:07 am    Post subject: Reply with quote
sweet, acording to the post in the general forum, i need them before april 9th Wink
PostPosted: Sun Feb 29, 2004 3:37 pm    Post subject: Reply with quote
J96Z
these are back up for sale, wolfman had to back out.
let me know if you are still interested.
