steering colum swap, not the best plan.
PostPosted: Mon Feb 20, 2006 1:16 am    Post subject: steering colum swap, not the best plan. Reply with quote
so, some of you may know i swaped the steering colum in my 86 w/ one from quasi tractions 84 maro. well, the new colum is not going so well. at first all seemed a-ok. the turn signals worked again, but the wipers worked even less. ok, no big thing. but now the brights won't turn off. looks like i am going to have to go to the junkyard and get one out of an 86 or newer. hopefully with delay. also, the battery in the 86 went out, and while it seems to not be related the timing is funny. perhaps some of the connections are not the same and i have somthing in the colum leeching power. i put the GTAs battery in there and got a new battery for the GTA. the old GTA battery had a good charge this morning when i made the swap, and seemed to be doing fine later tonight. lets see how it is on the way to the junkyard tomorow. hopefully i get home Smile
so heres my question.. how hard is it to change an ignition cylindar? do i have to pull the colum apart? that thing scares me, so many little pieces Sad . i do have a steering wheel puller.
PostPosted: Mon Feb 20, 2006 9:29 am    Post subject: Reply with quote
Oh s---t..... Now I totally feel bad dude. Do you want your old column and the money you paid back? I'll be willing to do some junkyard shopping with you this week and give you a hand getting a different column out. I feel like this is my fault so I should try to make this right. I can also help you with swapping an igniton cylinder if you want.
PostPosted: Mon Feb 20, 2006 10:11 am    Post subject: Reply with quote
omg... dude chill. how could we have known.... if you want your old colum you can have it. especialy since i broke the colum from the 86s seal Embarassed . anyway i'm gonna call you right now and see if ya wanna go to the yards. i was in shower when you called.
PostPosted: Mon Feb 20, 2006 11:10 am    Post subject: Reply with quote
Told you you should have just replaced the insides!
PostPosted: Mon Feb 20, 2006 4:10 pm    Post subject: Reply with quote
SCREW YOU HIPPIE! oh, yeah youre right. junkyards had no good ones. only nontrashed one out of an 86+ had no tilt Confused anyway....
