Posted: Sun Mar 29, 2015 5:50 pm Post subject: A little carb adjustment |
Actually worked on the 87 a bit. After going through the ignition system I was still picking up misfires at part throttle high load situations. Was thinking it was probably going lean at this point. So since I had to work on the carb anyway, I went ahead and checked the ccc primary adjustments.
First thing I needed to do was replace yet another choke thermostat. Electrically it tested fine but it would never open the choke. So I gave up on Napa thermostats(besides they're $55!!!) This is like the 4th one i've installed. Ordered a Standard brand one from Amazon. $22. I've never had the choke open so quickly before. I like!
Then I was figuring the Rich stop for the primary metering rods might be set too lean. Dug out my CCC adjustment tools and went to check it. Only 2/32's of travel in the metering rods. This just might be it! When I rebuilt this carb (L69 carb from Bart's bird) I left the adjustments alone because once you start messing with them they never seem to be right again. Of course that assumes they're right in the first place. lol
Got the stops adjusted up and then used the IAB gauge to check the air bleed. Adjusted that to preliminary spec and started her up. Hooked my dwell meter to the check wire and 28*! Spec is 30* so that's damn close. Whole reason I put this carb on was the old one would never even come close to spec and still run. 1/2 turn on the air bleed and it seems to be running fine and in spec. Amazing.
Haven't driven yet, but free revving I seem to have gotten rid of a dead spot it had. My fingers are crossed.
I'm also finally fed up with the stock TCC lockup program. It's especially bad now that I have a stall convertor and lock/unlock is a good 5-700 rpm difference. 35-40mph its always switching and then once its locked it's next to impossible to get it to unlock and shift down. This 700 really doesn't shift that nice. I wish it worked like the 200 4r I had in the truck. That thing would even shift down and compression brake when you let off. Also always seemed to find the right gear in the corners. Even with the probuilt shift kit the 700 is always in the wrong gear. Usually too high. (laugh stick boys, laugh)
I've tried a hypertech chip because they say they raise the tcc lockup point. If they do it must be by 2mph.
Anyway, enough I say. Bought a B&M TCC controller. Haven't installed yet, but just looking where i'll put the control box. Think I'll dig out the rotary cutter and put it in where the ash tray goes. This will be easily accessible, yet still hidden. |
fiveoformula Member
Posted: Mon Mar 30, 2015 2:15 pm Post subject: |
| I never liked the way my 700R4 shifted either. car seemed like it lugged around everywhere, in an RPM under its happy powerband. Unless I shifted manually. |
Posted: Tue Mar 31, 2015 7:22 pm Post subject: |
While it runs better, got rid of all hesitation, It still misses part throttle heavy load. I swear its ignition but everythings been replaced at least once. Also scoped it today and ignition looks good for as far as I can load the engine. |
Posted: Tue Mar 31, 2015 9:57 pm Post subject: |
Too much timing there? _________________ A redline a day keeps the carbon away! |
Posted: Wed Apr 01, 2015 6:21 am Post subject: |
| Interesting idea. Maybe part of the hypertech chip's map. I'm getting no knock though. Should probably swap that back and see. |
Posted: Wed Apr 01, 2015 11:33 am Post subject: |
It could be a lean miss compiled by timing. I didn't like the hypertext maps they were way too agressive. _________________ A redline a day keeps the carbon away! |
Posted: Wed Apr 01, 2015 7:05 pm Post subject: |
| Since the chip didn't do what I wanted it for anyway, it won't be a big loss. They're actually kind of hard to get for an lg4 now. |
Posted: Thu Apr 23, 2015 8:07 pm Post subject: |
Had to get on the ball and finish installing the TCC controller. Got it set at 50mph at the moment. Nice not to have that kick in and out while city driving. Also swapped the chips over. Will need a drive to Longview to know if it did anything.
Deb's gotta drive the old beast to work a couple times. The yota came home with a seized brake caliper last night. (have I ever said anything about napa parts?) Caliper is 1 year and a week old. Think every vehicle we have as an issue right now, unless I just fixed the 87s. |
Posted: Fri May 15, 2015 8:50 pm Post subject: |
Well seemed alot better but still has a miss under load. Then I got on it on one of the last hills on the way home and I think I have another issue as well. Seemed to run out of fuel. Went lean and had the typical fuel pump surge until I let off on it.  |
Posted: Sat May 16, 2015 11:44 am Post subject: |
| Does that car have the helper lift pump and then a mechanical pump? Could be that the lift pump died and the main pump is pulling through it. |
Posted: Sat May 16, 2015 11:49 am Post subject: |
| Lift pump probably doesn't have 500 miles on it. But yeah. new doesnt equal good. |
Posted: Sun Jun 07, 2015 5:16 pm Post subject: |
| So a couple weeks ago ran fine to Schultz bday party and back. Fired it up today to head to town, no problems getting to town. Then she won't idle. At all. Even while coasting she dies. So I baby it home. I'm thinking vacuum leak. Close the choke flap - no change, pop a vacuum line off runs worse. Float bowl appears to be full, and the metering rods are clicking away. Plugged idle jet? I don't know.. I think I have some .223 ammo here with its name on them. |
Posted: Sun Jun 07, 2015 8:54 pm Post subject: |
| chevymad wrote: | | I think I have some .223 ammo here with its name on them. |
It does wonders for the frustration. |
Posted: Sun Jul 19, 2015 8:06 pm Post subject: |
| Didn't get enough time to figure out the idle problem. But may have found the lean issue. Seems the purge solenoid is stuck and supplying vacuum to the tank at all times. |
Posted: Mon Jul 20, 2015 4:49 pm Post subject: |
| Well, my first Rockauto order. Solenoid is obsolete through napa. Cheaper through rockauto anyway.. even with my discount. |
Posted: Mon Jul 20, 2015 6:18 pm Post subject: |
I order through rockauto all the time....for work, and then resell to shops.  _________________
Posted: Mon Jul 20, 2015 7:45 pm Post subject: |
| Our catalogging is so screwed up that the parts guy regularly uses rockauto's to find a part # then crosses it on our system. |
Posted: Mon Jul 20, 2015 8:40 pm Post subject: |
Carb's gotta come apart again too. Tried cleaning out the idle passages externally, had it running nearly ok but kinda rough.. No sign of vacuum leaks anywhere with the purge cut off. Then gave it the rev and full choke treatment hoping it would suck the blockage through. Instead it seems to have made it much worse. Tells me something is caught in the idle passages.  |
Posted: Mon Aug 03, 2015 5:09 pm Post subject: |
And it runs again! Then it doesn't Disassembled and cleaned the carb out. Reset everything. Broke the factory gm tps putting it back together. Installed a new one and then set a code. Scanner showed new one only registering between 4 and 5v. Took carb apart again and sensor wouldn't go below 4v. So I disassembled my original carb and stole the tps out of it. This one works. Found 3 different vacuum caps that had rotted. So ordered a set of Buma N rubber caps. Hopefully they last longer. Replaced the purge solenoid with the replacement version. Still waiting for the proper harness to arrive, but rigged something up. Go for a drive to Castlerock. Runs pretty good.
But, on the trip my tach dies. Started jumping around and then just quit. Hasn't moved since. RPM still ok on scanner so its probably the tach itself. My indiglo gauge overlays have been acting up lately too, so I figure on removing that whole dash panel, installing the speedo and a set of led's in my original panel and putting that in the car.
Car still had a part throttle/heavy load miss. Drove it into work this morning to change oil. Got on it to pass a load of bicyclists (250 of them stayed the night at the local park last night) and it fell flat on its face. Hooked up the scanner again coming home. Get on it and it runs good/o2 goes to 0.86v for a few seconds, then it falls flat and starts surging. O2 goes to 0.01. Figure the carter mechanical pump has died and i'm probably just running on the 1/2 psi in tank pump. I guess its been a few years. I originally switched to the big carter because i'd gone through 5 or 6 factory replacements in 2 years. I blame the ethanol and the aftermarket not caring about carb cars anymore. Kicking myself for not just installing a tpi pump and a regulator.
Checked napa today for a new carter pump. Napa switched over to Airtex pumps now. The direct crossover for an airtex 120gph pump is no longer available anywhere. They currently recommend one of those pos external electrics. So online I go once more.
This shits getting old. On our drive the passenger seat belt also locked up twice.. and the headlight refused to come up the first time I turned the lights on.
Anyone want to buy a car? It's practically new!
And to top it off, I went to change oil and we didn't have a single old school chevy v/8 oil filter. No 1060, 1061, or 1069's in stock at all. So had to put that off as well. |
Posted: Mon Aug 03, 2015 7:20 pm Post subject: |
Ha! This problem is cheap and easy. So much so I feel foolish, but hey.. won't cost me much to fix. The in carb fuel filter won't even pass air! No sign of any particles at all, but the paper is turning dark. I removed the check valve and tried to blow through it.. Got about 3 bubbles and then it stopped up completely. Gotta be great gas to plug this thing up.
I did verify that both pumps work fine while I was at it. Even checked the cam lobe to make sure there was plenty of travel. All that looks good. Maybe that part throttle miss will finally be gone.
I didn't put this carb on all that many miles ago. Was fully kitted, new solenoid and filter at that time. So didn't even look at the filter this time. Maybe I can check the forum.. see when I actually did that. |
