colored hvac lines...
91camaro_rs
PostPosted: Sun Sep 28, 2014 9:31 pm    Post subject: colored hvac lines... Reply with quote
ok guys im stumped. i never really paid attention to this until now... on the back of heater controls all the colored lines, the gray and purple split off and have a connection where they go to the firewall and purple goes to vacuum ball/vacuum source and gray goes out to heater control valve... what if i dont have the control valve or the vacuum ball what do i do? this makes me think to because im doing this for the 83 lsx..but my 91 doesnt have the ball or control valve either....any insight??
PostPosted: Sun Sep 28, 2014 9:34 pm    Post subject: Reply with quote
Both lines can be capped.
Do you have cruise on either car?
PostPosted: Sun Sep 28, 2014 9:38 pm    Post subject: Reply with quote
And you must have the check valve or the vacuum ball will be useless.
PostPosted: Sun Sep 28, 2014 9:42 pm    Post subject: Reply with quote
Yup.
Actually you need a check valve of some kind in the HVAC line with or without the reservoir to prevent the doors from reverting to default positions under throttle.
91camaro_rs
Aaron no cruise on either car and non a/c as well. shouldnt the purple line at least go to a vacuum source? how do all the other colored ones get vacuum supply?
PostPosted: Sun Sep 28, 2014 9:47 pm    Post subject: Reply with quote
Purple line needs to see manifold vacuum to shift the doors, and a check valve to keep them in place.
GM used the same check valve on every single vehicles for over two decades, just grab a couple at the yard. It's the cone-shaped three-way thing near the firewall.
The vacuum reservoir is for cruise control. GM did not use it for the solenoids like Ford did.
91camaro_rs
PostPosted: Sun Sep 28, 2014 9:54 pm    Post subject: Reply with quote
ok so cap the gray one, purple to check valve and then to manifold easy enough!
now i gotta go look at the 91 tomorrow to see what the heck i did with that setup lol
as you might have been able to guess the 90's style dash swap is in progress in the 83
