MrMike98 Member
Posted: Fri Jul 25, 2014 3:40 pm Post subject: LS1 VIN code differences |
for LS1 98-02, there are 2 vin engine codes for 5.7 engines-8 and G..
whats the difference??
thanks |
Posted: Fri Jul 25, 2014 8:15 pm Post subject: |
| If you're talking about the change from the older style LS1 to the newer it was LS6 intake, better exhaust manifolds, different cam and lack of EGR. |
MrMike98 Member
Posted: Sat Jul 26, 2014 8:00 am Post subject: |
for the same year-ex. 2000 there are two 5,7 V8 LS1 vin codes.
"G" nd "8"
are they both al. block and heads?
just curious as to what the difference is-
thanks |
Posted: Tue Aug 05, 2014 6:25 pm Post subject: |
Probably differentiating between the engine for Z28 vs SS.
If you're looking to do an engine swap then the only difference worth mentioning is the SS has a better intake (LS6) but I think they only did that in '01 and '02. The other minor differences amount to nothing in terms of performance.
Always do a cam swap and full length headers with LS1. It is cheap and a huge power gain. |
