My '91 Z28
Goto page Previous  1, 2, 3, 4, 5, 6, 7, 8, 9
PostPosted: Sat Oct 19, 2013 7:13 pm    Post subject: Reply with quote
DBL_TKE wrote:
The car will not be an autocross car anymore, at least not competitively ... truth be told it will be a street car that will see a lot of roll racing.
That's an extremely important distinction.
In that case the first idea I would ditch is the transmission. A T56 built to withstand the amount of power you will be making will do nothing but bleed money. You will be regearing the car anyway to get the turbo to spool, so now is the chance to put a high rear gear in it and save yourself four or five thousand dollars in transmission work.
Second is any thought of 60lb injectors. I run 60lbs Deka's on the veesix. You need 80lb minimum.
Don't throw a lot of money into the engine. It doesn't need it to make power.
How is the E85 availability around Portland?
PostPosted: Sat Oct 19, 2013 8:26 pm    Post subject: Reply with quote
What other 6 speed manual transmission would you suggest then? Theres no way I'll ever put an auto in this car.
And you're right, 60lb injectors will be a bit small. I think when i ran it through an online calculator i inputed RWHP rather than at the flywheel.
I'm not going to be doing anything fancy to the engine. everything will remain stock with the exception of maybe some good valve springs and rockers.
Theres only a couple pumps within 25 miles of me, and they are all out of my way. Though I know several people that just buy drums of it and fill up at their house. But I also plan to go out of state and do a few road trips so I think I'm going to stick to 92 pump gas. I do plan to run water or meth injection though.
PostPosted: Sat Oct 19, 2013 9:11 pm    Post subject: Reply with quote
your bumper will be black.
Except he has an up-pipe in a vert so...
It's pointed at the passenger so what do I care? Very Happy
PostPosted: Sat Oct 19, 2013 9:30 pm    Post subject: Reply with quote
Just don't blow a headgasket. LMAO
PostPosted: Sat Oct 19, 2013 11:36 pm    Post subject: Reply with quote
T56 Magnum will hold up but that's going to melt the credit card.
You're looking at a $15K build the way you're headed.
PostPosted: Mon Oct 21, 2013 8:16 am    Post subject: Reply with quote
Hence the reason why it won't be done next year but I still don't plan to spend anywhere near that much. I'm looking at about $4k for the engine build. Then I just need to factor in the transmission, clutch, hydraulics, swap mounts, and other miscellaneous things but I don't see that nickeling and diming me up another $10k or so.
PostPosted: Mon Oct 21, 2013 10:16 am    Post subject: Reply with quote
Axle, clutch and trans are already pushing up towards 10K.
Not even counting the "nickel and dime" stuff.
At the power level you're talking about you will spend 4-6K on the trans alone.
A TH400 can be built to hold that power for 1/4 of that price. You can flip the logs instead of buying a TIG machine. You can run that engine as-is instead of pouring four grand into having it done up.
None of the people in the thread have finished their projects yet, and none of us are even building up to the power numbers you want.
Internet advice is, of course, worth what you paid for it, but think about yourself in ten years deciding whether you should throw money at the "project" car or buy curtains for the wife.
PostPosted: Mon Oct 21, 2013 11:38 am    Post subject: Reply with quote
Listen to these guys. They're not just flipping you crap. At 600hp you will break everything and spend way too much building everything bulletproof. I would say almost all of the same things but I don't need to so instead I'll just sit back and watch.
Stick to the old 80/20 rule and use a mostly stock T56 and regeared 9-bolt with a basic cam/head 5.3. You'll get out of the build for $6-8k instead of $20k and still make nearly 400RWHP. Wouldn't that be a fun, attainable goal?
PostPosted: Mon Oct 21, 2013 11:51 am    Post subject: Reply with quote
Or... Just don't let it hook up! But if it does be prepped to replace parts.
PostPosted: Mon Oct 21, 2013 9:10 pm    Post subject: Reply with quote
400hp doesn't exactly satisfy me. To me, a C6 corvette is just too slow. I've driven and rode in plenty of cars with that and much, much more power (most using stock transmissions btw) and know that I would get bored with 400hp very quick. C6 z06 power levels would be the minimum I would want. I can get a 600ft/lb rated MN12 for under $3500 and I've found a source for a 700ft/lb T56 magnum for $2900, though I'm still looking into that one to figure out why it's so cheap compared to other vendors. I forgot the source but a friend of mine has an MN12 in his 500hp LS3 RX-7 that he purchased for $3200 through a vendor on one of his forums and im most likely going to go that same route. All three of my friends with the 5.3/S400 engine/turbo setup have done it for around $3k including the engine and every nut, bolt, hose, etc. I'll use my 10 bolt and replace as necessary when it blows up. Eventually I'll get a nice 9" but that would be later on.
PostPosted: Tue Oct 22, 2013 8:15 pm    Post subject: Reply with quote
You probably shouldn't test the limits of a c-clip axle at high speed.
PostPosted: Tue Oct 22, 2013 8:39 pm    Post subject: Reply with quote
As someone said up above, the 9 bolt would be an ok upgrade for awhile. Easy enough to find and bolts in. I think they don't use c clips either. It won't hold up forever but better then the 10.
PostPosted: Tue Oct 22, 2013 8:46 pm    Post subject: Reply with quote
I've already been on the lookout for a 9 bolt to hold me over, actually. Tried getting one just a couple weeks ago but it had already sold.
PostPosted: Mon Jan 13, 2014 2:09 pm    Post subject: Reply with quote
ETS intercooler. 22x12x3.5 with 2.5" inlet/outlets. Thanks to Aaron.
PostPosted: Sun Mar 02, 2014 5:12 pm    Post subject: Reply with quote
Just picked up a turbo. Nearly half off retail and new in the box. It's a Borg Warner S400SX3 (S471) 71mm 1.10 A/R T4 housing. P/N 177248. I decided against the larger S475 because ultimately I would never use the full potential of that turbo. This one should spool a little better and have better response.
Page 9 of 9
