turbo_jimi Member
Posted: Thu May 02, 2013 8:22 pm Post subject: Edelbrock Fuel Pump 1721 |
Hi. John and I installed this last Saturday in the 85 because the stocker was leaking oil and about to explode. It has no return line. Do I need to vent this? Also, the throttle response seems better. Is that my imagination or can a fuel pump do this? Also, will I need to adjust my AFR on the carb due to the swap? It seems like it drives better but did notice the fuel odor was a little stronger than usual but nothing leaking. _________________
Posted: Thu May 02, 2013 8:36 pm Post subject: |
| If the old pump wasn't keeping up then you might notice a difference. Shouldn't need to change anything. |
turbo_jimi Member
Posted: Thu May 02, 2013 8:42 pm Post subject: |
Cool! _________________
Posted: Fri May 03, 2013 5:28 am Post subject: |
The return line was a vapor lock thing IIRC. I would cap that line well as it is submerged and could theoretically siphon if there were pressure in the tank.
Do you have a normal functioning tank vent? |
turbo_jimi Member
Posted: Fri May 03, 2013 6:06 am Post subject: |
| aaron_sK wrote: | The return line was a vapor lock thing IIRC. I would cap that line well as it is submerged and could theoretically siphon if there were pressure in the tank.
I believe so. _________________
jchaussee Member
Posted: Fri May 03, 2013 1:49 pm Post subject: |
| What does normal tank vent entail? |
Posted: Fri May 03, 2013 8:42 pm Post subject: |
| 1/4" steel line from top of sending unit to charcoal can underhood. |
jchaussee Member
Posted: Sat May 04, 2013 12:08 am Post subject: |
| I do not have then. I have a rubber hose on end od that line under my hood that goes to inder car |
turbo_jimi Member
Posted: Sat May 04, 2013 8:56 am Post subject: |
| aaron_sK wrote: | | 1/4" steel line from top of sending unit to charcoal can underhood. |
I have the line but not the can. _________________
Posted: Sat May 04, 2013 10:34 am Post subject: |
Put a filter on the end of the line. _________________ '86 Trans Am - 5.0L TPI - LT1 cam - 700R4 - WS6
turbo_jimi Member
Posted: Sun May 05, 2013 4:25 pm Post subject: |
Which line? _________________
Posted: Sun May 05, 2013 6:17 pm Post subject: |
The one that originally went into the charcoal canister.  _________________ '86 Trans Am - 5.0L TPI - LT1 cam - 700R4 - WS6
