gvmv New Member
Joined: 28 Feb 2013 Posts: 14 Location: United States
gvmv New Member
Posted: Mon Mar 04, 2013 8:23 pm Post subject: |
I meant to post this in the youtube thread, hehe. Anyways maybe others will post up there Solo video's  _________________ 2012 Camaro 2LT/M6
1993 Camaro Z28 LT1/A4
1991 Camaro Vert RS 305/A4
1989 Camaro Iroc-z TPI 305/A4
Among others.......................
Posted: Tue Mar 05, 2013 9:57 am Post subject: |
I've uploaded one of my videos so far. Watch it in HD. This was my best competition run.
http://youtu.be/fazvcl0ITtk _________________ Richmond 3.73 posi| 36/24 sway bars | SLP LM2 | Koni's | Ground Control 800/200 | Y2K wheels | Dyno Don headers & Y-pipe | airfoil | BBK underdrive pulleys | Raised strut mounts | Extended ball joints | LCARB'S
Posted: Tue Mar 05, 2013 10:09 am Post subject: |
Skyler, not sure if it is just the crappy camera sound, but it sounded like you at places could have pushed harder, I heard very little if any tire squelch during most of the run, but on the two sharp hair-pins, it sounded like you were a little heavy on the throttle getting out, and spinning up the tires. An in car view would help, but it might be a matter of a slight change of line and late apex the sharp corners and get the car straightened out more to get on it hard, or roll your speed longer and pick up the throttle a little more progressively.
Car looks good with the black wheels though.
I might have to get my rear axle sorted out and try to make an event sometime this summer. Although I am not a fan of shagging cones! But, it would be good to get the old girl dancing again. |
Posted: Tue Mar 05, 2013 4:14 pm Post subject: |
The video may be a little deceiving, but these tires are very quiet. There was, in fact, almost no point during my runs where the tires weren't fighting for grip. Coming around the hairpin I was fighting understeer every time. That was the only place that I spun the tires coming out of the corner. I wish our factory posi's were better. There was no point in the runs where I was full throttle either, I've made that mistake before. I was trying to be as smooth as possible when getting on the throttle. But all very valid points. I've been working on trying to frontside the cones a little more often. Most of the course set ups at PIR are very tight.
Don't forget that I have an extra rear diff. there is visual wear on the ring gear but it never made any noise when I was running it. It's yours if you want it. If anything, you should throw it under the car just if it means that you can get to drive it while you find a more suitable rear end. |
Posted: Wed Mar 06, 2013 6:38 am Post subject: |
| I just need to get out and fix mine. It howls (thought it was the trans, but its rear end). I really just need to pick a time to pull it out and press new bearings on. I am pretty sure that is all it will need. |
AMAXRX New Member
Posted: Fri Mar 22, 2013 1:15 am Post subject: |
I also got some videos up from that event. There is also old stuff on my channel, if you want to laugh at my old pitiful tires...
http://www.youtube.com/user/amaxrx/videos?flow=grid&view=0
Just to note, I still had the 3.08's and a dead factory posi in these videos. Looking forward to seeing what the torsen does at the next event. _________________ 1991 Trans Am WS6 AutoX Project. 305TPI T5. 3.42 Gears 4th Gen Torsen, Spohn SFCs, BMR STB, KYB Shocks, Poly Endlinks, 36/24 sways. Lots of refreshed stock parts. More to come. |
