Posted: Tue Apr 24, 2012 7:50 pm Post subject: |
| How wide are you going, or are you just re-offsetting them? |
charlie6178 Member
Posted: Tue Apr 24, 2012 8:10 pm Post subject: |
I'm going 17x9.5 with a 5.5" BS with a 275/40/17 tire all the way around. I was hoping for a little more lip, but whatever. It will work! Look stock, and sit way flush. Should look pretty clean aslong as everything works as I plan lol like I said that's just the first rough draft. I figure I'll have to cut, and re tack it numerous times before I actually figure out exactly how I'm gonna make all 4, the simplest, strongest, and most sanitary design. But roughly, that's what it'll look like. But the face will have a fresh, remachined finish, and they will be clear coated. _________________ 1992 Camaro 1LE Z28 |
Posted: Tue Apr 24, 2012 10:20 pm Post subject: |
You can definitely have a bigger lip, just go wider. 10" will be pushing it in the front for a 17" diameter wheel but will be doable if you still use a 275 wide tire and just go with an 11" wide rear wheel. If it were me I'd make it a 3 piece wheel in an 18" diameter. _________________ Richmond 3.73 posi| 36/24 sway bars | SLP LM2 | Koni's | Ground Control 800/200 | Y2K wheels | Dyno Don headers & Y-pipe | airfoil | BBK underdrive pulleys | Raised strut mounts | Extended ball joints | LCARB'S
charlie6178 Member
Posted: Wed Apr 25, 2012 6:06 pm Post subject: |
going wider will just push the barrel further into the wheel well, it won't give you any more lip. once the lip is at the edge of the fender, and the center is bolted down, it doesn't matter how wide you make the wheel, the lip is still going to be in the same place.
the original plan was to build the wheels at a 3 piece, and i still haven't 100% ruled that out as a last resort. if i do it as a 3 piece wheel, i'll hide the bolts on the back side like Fikse does tho.
the reason i like the 17x9.5 all the way around is the availablity, and price of the 275/40/17 tires, and i like the idea of the same size tire on all 4 corners. i wouldn't hate 18's, but i think 17's are a little more reasonable, and i already had a few 17's to cut up lol _________________ 1992 Camaro 1LE Z28 |
Posted: Thu Apr 26, 2012 1:37 pm Post subject: |
If possible, you could cut out the mounting pad and make it a lot shallower, that way the face of the wheel sits inbard more, essentially allowing you to have a larger dish. _________________ Richmond 3.73 posi| 36/24 sway bars | SLP LM2 | Koni's | Ground Control 800/200 | Y2K wheels | Dyno Don headers & Y-pipe | airfoil | BBK underdrive pulleys | Raised strut mounts | Extended ball joints | LCARB'S
charlie6178 Member
Posted: Thu Apr 26, 2012 3:28 pm Post subject: |
That is 100% accurate. But... Easier said than done. I looked at that. Not absolutely impossible, but it will be ALOT more work to do. I wanted to start on my set of wheels this weekend, but I have a dog show to go to with my lovely girlfriend, so probly gonna have to wait til next weekend. _________________ 1992 Camaro 1LE Z28 |
charlie6178 Member
Posted: Sun Feb 24, 2013 8:48 am Post subject: |
back from the dead! so after a breif break from the third gen, i spent a few hours pushing parts towards the car last week, put a new battery in it, and fired it up! not necessarily to drive it, but to get some solid motivation to GET IT DONE FOR SUMMER!!!!!
i got all of the painted parts atleast on the car. everything still needs a few more screws, and to me all aligned and tightened, but none the less, it's all there! i went though my parts pile for it, and separated, tossed out, and organized everything for the car. i'm going to go through and make a list of what all i need left to get it dont this week, and try to keep progress going on it. it's pretty damn close to being on the road!
as far as the wheel delimma... i decided to go with a wheel that was an off the shelf wheel for now. most of you will be suprised to see it on a gen 3 car.. TT2's!!!!!!!!!!!!!!!!!!!!!!!!!! what?!?!?! original??? yes... i know. but i had the front wheels, then i scored the rer 17x11's with brand new 315 DR's for dirt cheap, so what the heck? through them on!
i think realistically i'm probably only about $1500-$2000 away from it being 100% done and ready to hit the streets!
i've just been lurking for a bit, and collecting parts, and working crazy hours at work, so i haven't had a moment to even think about the car recently.
i did score a pair or 113 casting aluminum heads, another 92 L98 roller block, and some bits and pieces to stash away for a motor build on the car later on down the road. i'd love to find a good deal on a TPIS mini ram, and a pair of the factory cast alumninum L98 corvette valvecovers to throw in the pile with those pieces!
Posted: Sun Feb 24, 2013 9:27 am Post subject: |
Looks good. Old friend had those wheels on a '88 white formula rose and it looked sweet. _________________ A redline a day keeps the carbon away! |
jchaussee Member
Posted: Sun Feb 24, 2013 9:41 am Post subject: |
| I have always liked the newer torque thrusts on these cars. |
charlie6178 Member
Posted: Sun Feb 24, 2013 9:47 am Post subject: |
yeah it doesn't look bad at all. i went 17x9 front with a 5" BS and 17x11 rear with the 7" BS so the lips and fit are identical front t rear. 255 front tire and 315 rear. i'm DEF doing to be putting some sportlines in it before it hits the road! _________________ 1992 Camaro 1LE Z28 |
Posted: Sun Feb 24, 2013 1:52 pm Post subject: |
I had 17x8 and 17x9.5 TTIIs with 245 fronts and 275 rears on my Z28 for a while. They're not a bad looking wheel, and I got mine basically free so there is that.
The car is looking real good man. _________________ 84 Camaro Z28 - LS1/T56
Posted: Sun Feb 24, 2013 6:30 pm Post subject: |
| Looking good, glad to see it coming back together. |
charlie6178 Member
Posted: Sat Mar 09, 2013 12:37 pm Post subject: |
so i got the rest of my deals and window felts, i'm going to pull the car into the middle of the shop, and put it up in the air so it's in my way every day until it's done! dyno day is the goal to have it on the road! _________________ 1992 Camaro 1LE Z28 |
