Can anyone find this?
PostPosted: Wed Dec 19, 2012 8:58 pm    Post subject: Can anyone find this? Reply with quote
http://www.rallydesign.co.uk/product_info.php?cPath=2243_2244&products_id=3450
On this side of the pond? Or anything similar? I'm just looking for an adjuster meant for a 2.25" ID spring (preferably steel). I picked up some dirt cheap springs and it'd be nice to be able to use them!
PostPosted: Wed Dec 19, 2012 9:04 pm    Post subject: Reply with quote
Universal weight jacks or coilovers? Try the roundy-round guys.
PostPosted: Wed Dec 19, 2012 9:10 pm    Post subject: Reply with quote
I've been trying! All I can find are 2.5" stuff, sucks!
PostPosted: Wed Dec 19, 2012 11:06 pm    Post subject: Reply with quote
I've found this;
http://www.colemanracing.com/Shock-Sleeve-Shrink-On-P3591.aspx
and this;
http://www.summitracing.com/parts/kon-8000000005/overview/
Not steel though. I may be stuck with one of them anyways. I have the 2.25 spring and adjuster nut already.
PostPosted: Thu Dec 20, 2012 6:50 am    Post subject: Reply with quote
http://www.speedwaymotors.com/
Who the f runs a 2.25" ID spring?! Standard is 2.5
PostPosted: Thu Dec 20, 2012 10:20 am    Post subject: Reply with quote
I'll give you a hint. BMW guys. Laughing Free springs/adjusters/pads means I'll do a bit more effort to find the threaded sleeve. Speedway is a cluster
PostPosted: Thu Dec 20, 2012 10:46 am    Post subject: Reply with quote
Yeah. But hey have a lot of that stuff. Their mag is way better. Web master should be fired.
PostPosted: Thu Dec 20, 2012 11:12 am    Post subject: Reply with quote
I bet bilstein and koni both sell the proper sleeves, its about knowing the shock body size.
Also, a phone call to ground-control may work, see if they have a sleeve that size, or southwest speed, coleman, or other misc circle track places.
PostPosted: Thu Dec 20, 2012 12:29 pm    Post subject: Reply with quote
Also, a phone call
That's what it's going to have to boil down to. Phone calls to parts houses (speed or OE) have always been the bane of my existence.
PostPosted: Mon Dec 24, 2012 7:41 am    Post subject: Reply with quote
I found mine from a Mazda 6 coilover kit. Did you try ground control?
