turbo_jimi Member
Posted: Tue Jul 24, 2012 1:50 pm Post subject: |
| jchaussee wrote: | | Wierd. I must have an early production 85 because that is exactly how mine is , just like tho diagram |
Probably...my 85 was built at the end of the model year. My original radiator was date stamped May 16, 1985. _________________
Posted: Tue Jul 24, 2012 7:27 pm Post subject: |
| turbo_jimi wrote: | | On ours, there is a metal bracket that screws into the skirt with two small screws. On that bracket, there is a speed nut "bolt" that would attach through the rear quarter panel that would need to be accessed inside the car. |
This is how mine was on my '85Z. I always thought it had a threaded stud with a normal nut inside the quarter panel though. Maybe I am mistaken. Mine was also a late manufacture date. |
jchaussee Member
Posted: Tue Jul 24, 2012 8:09 pm Post subject: |
| So with this info, it looks as if I need to look into a 84. But I may be putting the aero efx on. So perhaps I will wait. |
Posted: Tue Jul 24, 2012 8:42 pm Post subject: |
The question is, do the GFX attaching styles follow year of the body panels, or the gfx? _________________ A redline a day keeps the carbon away! |
jchaussee Member
Posted: Tue Jul 24, 2012 9:14 pm Post subject: |
| It would be body panels I assume, but the efx I am sure play into it |
Posted: Sun Jul 29, 2012 9:22 pm Post subject: |
| aaron_sK wrote: | Body kit, yes. Functional exhaust and carb, no.
Is the door now the last thing before paint? |
Priorities!!!  |
turbo_jimi Member
Posted: Sat Aug 11, 2012 3:00 pm Post subject: |
Door Swap...not too difficult... _________________
Posted: Sat Aug 11, 2012 11:03 pm Post subject: |
Wasn't nearly as bad a job as I thought it would be. Definetly a two man job though! Glad to be rid of the dented, rusty, and sagging door!  _________________ '86 Trans Am - 5.0L TPI - LT1 cam - 700R4 - WS6
Posted: Sun Aug 12, 2012 11:55 am Post subject: |
