91camaro_rs Member
Posted: Thu Jun 14, 2012 4:46 pm Post subject: ecm/ prom help please |
Ok so i have the 7730 ecm speed density tuned port. I have a 91 305 prom but i have the Aujp chip on it. About every 2-3 weeks the prom fails code 51. Am i doing something wrong when i burn the chip or is my ecm bad? This is like the 4th time its happened _________________
Posted: Thu Jun 14, 2012 7:56 pm Post subject: |
| Same chip every time? |
91camaro_rs Member
Posted: Thu Jun 14, 2012 10:05 pm Post subject: |
Two different ones. Think maybe the chip is done? _________________
Posted: Thu Jun 14, 2012 10:17 pm Post subject: |
Chip is kinda dumb. Never heard one "go bad" over time of use. Excess of burns yeah, or just stops yeah. But never I burned it and it was fine for a month.
I'd be leaning ECM.
Which chips are you using?
You try removing and reinstalling the chip/adapter etc and key on again? Eliminate bad connnection? _________________ A redline a day keeps the carbon away! |
91camaro_rs Member
Posted: Thu Jun 14, 2012 10:45 pm Post subject: |
im using the SST 27S512 chips. i ordered a new ecm tho so gonna swap that out in the morning
i swapped to another chip with the aujp on it and it worked but that chip that i swapped was the one that went bad on the dyno, so im thinkin ecm now _________________
Posted: Fri Jun 15, 2012 8:44 am Post subject: |
I never had luck even getting those sst chips to work. The Atmel chips I had worked great. _________________ A redline a day keeps the carbon away! |
91camaro_rs Member
Posted: Fri Jun 15, 2012 2:20 pm Post subject: |
where abouts do i get the atmel chips at? _________________
Posted: Fri Jun 15, 2012 2:36 pm Post subject: |
They're obsolete and discontinued. I have one or two of Paul's that I need to return to him, since I don't need chips any more. _________________ 92 Camaro
91camaro_rs Member
Posted: Sat Jun 16, 2012 8:20 am Post subject: |
there is some on ebay. run about $7 a piece, worth it? _________________
Posted: Sat Jun 16, 2012 12:04 pm Post subject: |
| 91camaro_rs wrote: | | there is some on ebay. run about $7 a piece, worth it? |
Even if they're not, you're only out $7!  _________________ '86 Trans Am - 5.0L TPI - LT1 cam - 700R4 - WS6
