		| Author | Message |
		| Al Hasse Member
 1992  Chevrolet  Camaro RS
				|  Posted: Sat Mar 17, 2012 12:35 pm    Post subject: 5-speed shifter cover |   |
				| Mine has been off and on so many times that the screw holes are all cracked.  Also, the tab for the ashtray lid spring is broken and the lid won't stay closed. _________________
		| Back to top |  |
				|  Posted: Sat Mar 17, 2012 8:21 pm    Post subject: |   |
				| I'd offer mine, but mine's not in too much better shape.....
 on an unrelated note....which hatch plastics were you looking for, so I know what to bring with me to dyno.
		| Back to top |  |
		| Al Hasse Member
				|  Posted: Sat Mar 17, 2012 8:32 pm    Post subject: |   |
				| I think I'm going to try to re-glue some carpet to the panels I have.  The only reason I was looking is because of the carpet coming apart.  Looks like for now, just the hinged cover...
 I should have added the radio trim to the listing as I noticed today that it's doing the same...
		| Back to top |  |
				|  Posted: Sat Mar 17, 2012 8:57 pm    Post subject: |   |
				| Good enough. I actually noticed that the big piece on the drivers side (one with the extra locked compartment in the hatch area) is having the same problem with the carpet towards the back seat.
 What'd you use as an adehsive? If it worked, I might try the same stuff.
		| Back to top |  |
		| Al Hasse Member
				|  Posted: Sat Mar 17, 2012 9:06 pm    Post subject: |   |
				| LOCTITE heavy duty spray adhesive that I bought from JoAnn's. The same stuff I used to attach extra foam to my seats before I covered them. |  |
		| Back to top |  |
