Best coolant flush
PostPosted: Tue Feb 07, 2012 7:19 am    Post subject: Best coolant flush Reply with quote
Hey guys, I'm battling the the previous owners lack of cooling system maintenance in the lt1. I've flushed it about 4 or 5 times and it still looks like swamp thing is living in my radiator. The radiator, water pump, heater core, and hoses are all brand new.
So my question is what is the best, most aggressive, harmful to the environment, stuff to clean out the rust and crap in the block?
-jake
PostPosted: Tue Feb 07, 2012 10:12 am    Post subject: Reply with quote
If you can find an OLD bottle of prestone flush. From like 15 years ago. That stuff kicked ass. They have redone it so that some dishwasher soap I swear would be better.
PostPosted: Tue Feb 07, 2012 5:58 pm    Post subject: Reply with quote
There used to be some old school powder that was awesome. The water would actually get hot when you added it.. major chemical reaction. Bout 4 or 5 years ago it disappeared from our shelves though. Now its all pretty much just soapy water.
PostPosted: Tue Feb 07, 2012 9:55 pm    Post subject: Reply with quote
This is the Cascade Crew, duder. You need to use a proper Cascade-approved cleaning solution:
Brandon suggested that to me one time because he had read it somewhere and we were out of ideas. Sh*t works like a charm. Here's what I did:
Dumped the coolant, pulled the stat, filled with water and added a generous amount of the liquid soap for automatic machines. Ran the car up to temp then dumped it out and did a normal flush & fill with the T in the heater line and all that jazz.
PostPosted: Tue Feb 07, 2012 10:08 pm    Post subject: Reply with quote
I forgot all about that. Worked well eh?
PostPosted: Tue Feb 07, 2012 10:14 pm    Post subject: Reply with quote
It did indeed. I wish I would have videotaped it. Laughing
The engine I used it in had been ruined by someone's use of radiator "repair" crap. The dish soap turned the clumpy clay sh** into a fine slush that just ran right out. The trick is to use the stuff for automatic machines so it doesn't aerate.
jchaussee
PostPosted: Wed Feb 08, 2012 9:48 am    Post subject: Reply with quote
So I have never really flushed a car. I have drained radiator, but never flush. So question is does the t thing go into one of the hoses that go into firewall and if o which one?
nonsensekid20
PostPosted: Thu Feb 09, 2012 11:28 pm    Post subject: Reply with quote
I was reading around and people have been saying dump 5 quarts of vinegar in and top off with distilled water and run it up to temp. Probly hotter temp than normal. Then flush. I'm glad this came up though because mine is really bad. I just paid $70 for eagle tire to do nothing.
PostPosted: Fri Feb 10, 2012 12:01 am    Post subject: Reply with quote
Fleetguard coolant restore is epic.
nonsensekid20
PostPosted: Fri Feb 10, 2012 6:27 pm    Post subject: Reply with quote
How hot should I get the car after adding the vinegar and water?
PostPosted: Fri Feb 10, 2012 9:34 pm    Post subject: Reply with quote
Dude, WTF is vinegar going to do? It's just a mild acid. May as well put orange juice in it. Laughing
PostPosted: Fri Feb 10, 2012 9:46 pm    Post subject: Reply with quote
It will get rid of the odor from last week's chicken pot pie that is clogged in the return hose.
PostPosted: Fri Feb 10, 2012 10:43 pm    Post subject: Reply with quote
Summer's Eve Coolant Flush
PostPosted: Sat Feb 11, 2012 4:37 am    Post subject: Reply with quote
That's like using ky as differential lube...
PostPosted: Sat Feb 11, 2012 8:18 am    Post subject: Reply with quote
No, it's called KY Axle Lube.
PostPosted: Sat Feb 11, 2012 8:20 am    Post subject: Reply with quote
All sorts of wrong here. My car does not have, a not so fresh feeling thank god.
PostPosted: Sat Feb 11, 2012 8:24 am    Post subject: Reply with quote
The kids continue to put the 'Ew' in 'Crew.' LMAO
PostPosted: Sat Feb 11, 2012 8:28 am    Post subject: Reply with quote
And that brings up a Two Live Crew song...
nonsensekid20
PostPosted: Sun Feb 12, 2012 6:45 pm    Post subject: Reply with quote
The buildup inside the radiator is calcium buildup from tap water. Vinegar is the same thing you use to clean out coffee pots with calcium buildup. It needs to get hot, then sit for some time and dumped and flushed. I was just asking how hot I should get the car before it gets dumped. What is in the Cascade complete that cleans out the radiator?
