For Dyno weekend I will be. |
Attending and dynoing a car |
61% |
[ 11 ] |
Attending and dynoing multiple cars |
5% |
[ 1 ] |
Attending, but not running a car on the dyno |
22% |
[ 4 ] |
Staying at home, wishing I was one of the cool kids |
11% |
[ 2 ] |
Total Votes : 18 |
jchaussee Member
Posted: Sat Feb 04, 2012 9:58 pm Post subject: |
I am almost sure ill make it. Want to get heads put on. Bit probably don't have enough time. Well are how this little 327 does. |
Posted: Sat Feb 04, 2012 11:00 pm Post subject: |
aaron_sK wrote: | I say he should go for one final hurrah. Mike is getting complacent up on his high-HP highchair. The young punk crew members are getting older, getting real jobs and starting to build. He needs to set a good high bar so he can sit around and drink while we all race to cobble sh*t together.
Richster wrote: | Hey Aaron you got it man, I just put one to the side and tagged it! |
Rich, bud, you rock! |
Hey at least it'll be a red trans am that de-thrones him. _________________
Posted: Sat Feb 04, 2012 11:03 pm Post subject: |
O RLY? |
Posted: Sun Feb 05, 2012 8:09 pm Post subject: |
LOL you guys are funny. I think Zac is the fast one.
I have been waiting for several years though. 'One final hurrah' sounds like I am done or something. Who is going to put up the big numbers this year... Aaron? Ian? Boosted Mazda?.... the tutu is dusty boys but we can clean it up for a proper bet here
-Schultzy |
Posted: Sun Feb 05, 2012 8:38 pm Post subject: |
Oh I'm just running my mouth this year, I'm not even sure the car will be running/sorted out by then. I'm a bit slow on big stuff like this. |
Posted: Sun Feb 05, 2012 8:42 pm Post subject: |
I think you are sandbagging Ian. You will be ready. Boosted LS1 > boosted vee six.... tutu, tutu, tutu
-Schultzy |
flea Member
Posted: Sun Feb 05, 2012 8:52 pm Post subject: |
I will try to run my car, but I don't expect any real impressive numbers. Might have to run the wife's high-brow Honda though.
Can't wait for this year. _________________ Killing mailboxes since 2009 |
Posted: Sun Feb 05, 2012 8:55 pm Post subject: |
I can't run the project car on Steve's dyno, and no use running the camaro (which has started whining in 5th, so I think I need to at least change the trans fluid) so, if Zee German Girl is running, I may just be that guy, and drive it to dyno to show off, and have a really good excuse to not dyno. |
Posted: Sun Feb 05, 2012 8:57 pm Post subject: |
cool John. I hope she is all dialed in by then. You will have to bring Layla though.
You were asking about FWD... I assume Mrs Jim's fancy Honda with an 'A' would be FWD
-Schultzy |
Posted: Sun Feb 05, 2012 8:58 pm Post subject: |
John, you just need to go get yourself a monogrammed dress shirt and a bluetooth earpiece and you'll be good to go with that Audi. |
Schultzy89GTA wrote: | I think you are sandbagging Ian. You will be ready. Boosted LS1 > boosted vee six.... tutu, tutu, tutu
-Schultzy |
If I knew for sure my junk would be running, I'd be down for some bets. Maybe as it gets closer. I still have to get my hot-side all finish welded.
Dewey316 wrote: | I can't run the project car on Steve's dyno, and no use running the camaro (which has started whining in 5th, so I think I need to at least change the trans fluid) so, if Zee German Girl is running, I may just be that guy, and drive it to dyno to show off, and have a really good excuse to not dyno. |
Can't we just yank the rear halfshafts? |
Posted: Sun Feb 05, 2012 9:03 pm Post subject: |
aaron_sK wrote: | John, you just need to go get yourself a monogrammed dress shirt and a bluetooth earpiece and you'll be good to go with that Audi. |
iansane wrote: |
Posted: Sun Feb 05, 2012 9:09 pm Post subject: |
I've been thinking about dropping a welded center and pulling my front stub shafts to dyno my Subaru... But the Camaro will be ready to go by then. _________________ 84 Camaro Z28 - LS1/T56
Posted: Sun Feb 05, 2012 9:14 pm Post subject: |
What are you doing to the Camaro Gabe? Your combo has actually been one of the most impressive in the last several years. You have done real good with that setup.
-Schultzy |
Posted: Sun Feb 05, 2012 9:19 pm Post subject: |
Alphius wrote: | I've been thinking about dropping a welded center and pulling my front stub shafts to dyno my Subaru... But the Camaro will be ready to go by then. |
One of the kids that works at Grease Monkey here in Bothell (used to be right next door to my work) picked up a turbo'd 2.5RS that has the front shafts yanked with the block off plates and runs a welded rear diff. Pretty cool seeing a RWD scoobaru. |
Posted: Sun Feb 05, 2012 9:21 pm Post subject: |
Schultzy89GTA wrote: | What are you doing to the Camaro Gabe? Your combo has actually been one of the most impressive in the last several years. You have done real good with that setup.
-Schultzy |
Thanks for the props! I've been consistently surprised how well the 624 casting stock truck heads have done with the rest of my parts. So this year, I've got a set of RHS Pro Action 200cc aluminum heads and a set of Scorpion Endurance 1.6 roller rockers going on. Hopefully getting rid of the last weak link in my setup will make a big difference. I'm also going to end up moving from a roughly 9:1CR up to about a 10.5CR. _________________ 84 Camaro Z28 - LS1/T56
Posted: Sun Feb 05, 2012 9:23 pm Post subject: |
iansane wrote: | One of the kids that works at Grease Monkey here in Bothell (used to be right next door to my work) picked up a turbo'd 2.5RS that has the front shafts yanked with the block off plates and runs a welded rear diff. Pretty cool seeing a RWD scoobaru. |
You finally moved across the street, Ian? |
Posted: Sun Feb 05, 2012 9:26 pm Post subject: |
Ha! Not yet! Grease Monkey and Safeway both left and now it's a ghost town down here. Both buildings are vacant until construction starts. I think people have forgotton I'm down here. |
Posted: Sun Feb 05, 2012 9:29 pm Post subject: |
Cool Gabe. It took several iterations to get my combo up to what it should have been doing. Part of that was a bump in compression. The performance with the truck heads was impressive but those mods should take you to the next level. You have the combo all tuned in now?
-Schultzy |
Posted: Sun Feb 05, 2012 9:33 pm Post subject: |
iansane wrote: | Can't we just yank the rear halfshafts? |
Nope, Torsen center diff, I would have to weld the worm gears and spider gears. |
