   1983  Chevrolet  Camaro Z/28
				 Posted: Sun Jan 15, 2012 12:15 pm    Post subject: crank hub repair sleeve |
				Hey guys, i've been battling a oil leak on the front of the motor ever since the LT1 swap. I first thought it was the oil pan gasket, and replaced it last weekend. Second, i thought it was the water pump drive or the opti seals. I replaced those last night and i'm still dumping oil...
I pulled the crank hub to replace that seal and found 2 small grooves on the hub. I tried to smooth them out a little but with some emery cloth and replaced the seal but it is still pouring oil out when rpm's rise.
I am now faced with 2 choices, either replace the entire hub or just get a repair sleeve. Has anyone used these before? since i can get a repair sleeve for about 10 bucks i'm leaning towards getting one and trying it out but if its just a band-aid fix for a month before i start leaking again i'll save the time and money.
   1987  Pontiac  Formula
				 Posted: Sun Jan 15, 2012 12:40 pm    Post subject:  |
				| Repair sleeve is a permanent fix if the rest of the hub is in good shape. |
   1991  Chevrolet  Camaro RS
				 Posted: Sun Jan 15, 2012 12:43 pm    Post subject:  |
				I would say it would depend on how big the grove is in the hub.  If its just a little bit, the sleeve should fix it.
If its a big grove, time for a new hub.
I would try sliding a sleeve on that hub before you put it together and see if it fixes it. |
				 Posted: Sun Jan 15, 2012 12:48 pm    Post subject:  |
				| Why would the size of the groove make any difference at all? The sleeve completely covers it. |
				 Posted: Sun Jan 15, 2012 1:02 pm    Post subject:  |
				I guess I'm thinking about a different part?
I'm thinking hes calling his crank harmonic balancer a "hub"? |
   1991  Pontiac  Trans Am
				 Posted: Sun Jan 15, 2012 1:25 pm    Post subject:  |
				 	  | chevymad wrote: | 	 		  | Repair sleeve is a permanent fix if the rest of the hub is in good shape. |
This. Sold many of those at the dealer and never had any comebacks. _________________
 	  | Quote: | 	 		  | Sometimes I actually think I'm slightly retarded in the mouth. |
				| Thats what i'm thinking too. The groove a seal will cut into the hub no matter how deep wont affect structural strength. So putting a stainless sleeve over it should be a permanent repair. |
				 Posted: Sun Jan 15, 2012 5:54 pm    Post subject:  |
				sounds like a plan, as long as it doesn't start leaking between the sleeve and the hub. I'm going to try one out tomorrow after work.
				 Posted: Sun Jan 15, 2012 6:29 pm    Post subject:  |
				| There should be a tube of loctite sleeve retainer to keep that from happening. Besides that.. they fit tight. |
