Fuel pump
PostPosted: Sun Dec 25, 2011 8:46 pm    Post subject: Fuel pump Reply with quote
I'm looking to use my Summit gift card toward a new fuel pump to feed my 383. Most I've looked at "fit TPI motors." Aside from the pressure output, what is the difference between the TBI and TPI pumps?
PostPosted: Sun Dec 25, 2011 9:16 pm    Post subject: Reply with quote
Volume.
TPI pumps are used as tbi upgrades.
Mounting identical.
The tbi regulator is pretty good. It can handle a stock TPI pump without being over run.
Something like a walbro high pressure pump, it might not be able to control pressure.
PostPosted: Sun Dec 25, 2011 9:43 pm    Post subject: Reply with quote
That's what I wanted to hear. I am looking at the Walbro. I also intend to replace the regulator with a variable piece but haven't decided if I want to use a block off plate and use external or to go with stock looking internal regulator.
BluFbdy
PostPosted: Tue Dec 27, 2011 2:12 am    Post subject: Reply with quote
I'm running a walboro high flow pump, pressure reg hasnt failed me yet and its been about 6 months
PostPosted: Tue Dec 27, 2011 8:16 am    Post subject: Reply with quote
They don't fail, they can be overrun. Meaning the pump puts out so much volume, a 12psi regulator... sometimes you can see 14-15psi. Of course I haven't seen it with TBI just something to be aware of is all.
BluFbdy
PostPosted: Tue Dec 27, 2011 10:36 am    Post subject: Reply with quote
Ah that makes sense, the car has smelled slightly rich since I did the pump, if I hammer on it once I release the throttle I can smell excess fuel under the hood, not enough to cause issues just a smell
