stupid question of the day!
PostPosted: Tue Oct 11, 2011 5:08 am    Post subject: stupid question of the day! Reply with quote
Does anyone know how to get the piece of ABS plastic that sits atop the door panel off without damaging the door panel itself?
PostPosted: Tue Oct 11, 2011 7:51 am    Post subject: Reply with quote
It's held on by those sheet nuts, but they're put on upside down. Almost impossible to remove without a special tool. I used a needlenose plier and got inside the recessed hex and with a lot of difficulty, was able to remove them, after a couple of turns, a regular set of pliers was sufficient. You can see the results in this thread, though I never did take pictures of the nuts removed.
http://www.cascadecrew.org/phpBB2/viewtopic.php?t=6065&highlight=door+panels
PostPosted: Tue Oct 11, 2011 10:56 am    Post subject: Reply with quote
Roll the window down and take the whole panel off the car first. Makes it much easier.
PostPosted: Tue Oct 11, 2011 12:08 pm    Post subject: Reply with quote
I tried removing mine with needle nose. The stud snapped Sad
PostPosted: Tue Oct 11, 2011 6:23 pm    Post subject: Reply with quote
so basically it takes time/patience/finesse?
Alright, I'll give it a go tomorrow, and hope for some luck.
