Posted: Tue Oct 11, 2011 5:08 am Post subject: stupid question of the day! |
| Does anyone know how to get the piece of ABS plastic that sits atop the door panel off without damaging the door panel itself? |
Posted: Tue Oct 11, 2011 7:51 am Post subject: |
It's held on by those sheet nuts, but they're put on upside down. Almost impossible to remove without a special tool. I used a needlenose plier and got inside the recessed hex and with a lot of difficulty, was able to remove them, after a couple of turns, a regular set of pliers was sufficient. You can see the results in this thread, though I never did take pictures of the nuts removed.
http://www.cascadecrew.org/phpBB2/viewtopic.php?t=6065&highlight=door+panels _________________ 92 Camaro
Posted: Tue Oct 11, 2011 10:56 am Post subject: |
| Roll the window down and take the whole panel off the car first. Makes it much easier. |
Posted: Tue Oct 11, 2011 12:08 pm Post subject: |
I tried removing mine with needle nose. The stud snapped  |
Posted: Tue Oct 11, 2011 6:23 pm Post subject: |
so basically it takes time/patience/finesse?
Alright, I'll give it a go tomorrow, and hope for some luck. |
