jchaussee Member
Posted: Mon Oct 03, 2011 3:11 pm Post subject: air dam |
| I need one cheap. I thought I could get away withouut one with fan constanly running, but traffic proved me wrong. Drove from renton to blvd park in seattle in morning no problems. Drove home with fan on, heat cranked in traffic and creeped north of 220, don't know how much air damn will help but can't hurt |
Posted: Mon Oct 03, 2011 3:12 pm Post subject: |
Air dam doesn't do anything for traffic.
It only works at speed.
Best check that your fan is really on, and put a 180 t-stat in there. _________________ A redline a day keeps the carbon away! |
Posted: Mon Oct 03, 2011 4:13 pm Post subject: |
| Twilightoptics wrote: | | Air dam doesn't do anything for traffic. |
It's just a thought, but my guess is that your problem lies with the engine timing. I think it's far too retarded at idle. |
jchaussee Member
Posted: Mon Oct 03, 2011 4:31 pm Post subject: |
| ya. i kindof figuered i have a problem beside air dam. i was thinking it could at least aid it when moving. i have a 160 degrees thormostat and my fan is wired to a toggle, i know both were working which is why i thought getting to 22o plus in thirty minutes driving was a little much. |
Posted: Mon Oct 03, 2011 4:39 pm Post subject: |
Yeah you do need the air dam. Mentioned that months ago to ya.
Toggle switch is a bad idea for a fan. It's nice to have a toggle in addition to a sensor/switch to turn it on automatically.
You'll forgot to turn it on one time..... one time only, and blow the radiator. _________________ A redline a day keeps the carbon away! |
Posted: Mon Oct 03, 2011 4:43 pm Post subject: |
| Twilightoptics wrote: | | You'll forgot to turn it on one time..... one time only, and blow the radiator. |
Not just the rad, you'll blow the whole motor. Think about Al's car at dyno. That was two pulls without the electric fan. Just two pulls and the whole thing was toast.
He's already been told he needs to install and air damn and an automatic fan switch. This was mentioned several months ago, as you said.
If he doesn't act on the suggestions we give then there is not any real reason to continue giving them, IMHO. |
jchaussee Member
Posted: Mon Oct 03, 2011 4:45 pm Post subject: |
| ya, i know i need to hook up fan correctly. and i know i need an air dam. fan i will get to this winter. i finally have started driving car more then to store and back. actually i only have onece, thhat was last thurs to s seaatle and back. first time on freeway since i got it. i am just getting bugs worked out. eventually i would like to be able to trust it going through more then one county |
| aaron_sK wrote: |
He did post in the WANTED forum for an air dam. Step in the right direction. :O) _________________ A redline a day keeps the carbon away! |
jchaussee Member
Posted: Mon Oct 03, 2011 4:50 pm Post subject: |
| i do act on them. as i can afford to. everything that has been suggeted i have done as money permits. yes i knew i needed an air damn, but have not driven car. now i have. hence post in wanted section. as far as swith goes for fan. believe me it is infinatly better then what the car came with. |
turbo_jimi Member
Posted: Mon Oct 03, 2011 5:31 pm Post subject: |
I think I have an extra one in the shed. $20 and I'll bring it the next time I'm in Renton. _________________
BluFbdy Member
Posted: Tue Oct 04, 2011 5:41 pm Post subject: |
| Twilightoptics wrote: | Yeah you do need the air dam. Mentioned that months ago to ya.
did it last night!!!! remote started my car before i left work and got hung up for a bit, temp was at 230 when i looked, killed the motor and let it cool off, i escaped with a stuck thermostat luckily _________________ If you expect a kick to the balls and get a slap to the face its still a victory
Posted: Tue Oct 04, 2011 5:50 pm Post subject: |
| Next time let it idle with the fan running to cool it off. Hot coolant gets hotter when it stops. |
Posted: Tue Oct 04, 2011 6:24 pm Post subject: |
| aaron_sK wrote: | | Next time let it idle with the fan running to cool it off. Hot coolant gets hotter when it stops. |
Yep. Best move is to run the fan, let it idle, and crank on the heater. _________________ A redline a day keeps the carbon away! |
Posted: Tue Oct 04, 2011 7:30 pm Post subject: |
| If the fan won't cool it down, you can mist water into the radiator fins. This will cool it down to thermo temp. Then you can shut down. |
